22947 Discussions
Can't get video output via HDMI on UHD 630 igpu
Leilouback
I have a monitor that supports HDMI and VGA via DVI, but I can only make it work via VGA. HDMI cable works normally outside Windows 10 (bios and splash screen). And if I uninstall the Intel igpu driver, HDMI works fine. I already installed the latest driver for this gpu on intel website (30.0.101.1340), but the problem persists.
How can I fix it? I already uninstalled and reinstalled the intel driver (from Lenovo and Intel) and it didnt fixed the issue.
ps: System bios is updated too.
JosueO_Intel
Hello Leilouback,
Thank you for posting on the Intel®️ communities. In order to have a better understanding of the issue, please share with us the following information:
  1. Was it working before?
  2. When did the issue start happening?
  3. Were any changes made recently to the system?
  4. Have you tried using an older driver?
Also, please download and install the Intel®️ System Support Utility (Intel®️ SSU):
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel®️ SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View".
Click on "Next", save the report and attach it to your response.
Josue O.
JosueO_Intel
Hello Leilouback,
Josue O.
JosueO_Intel
Hello Leilouback,
Josue O.
