22963 Discussions
Can't upgrade to the latest drivers with Driver Update Utility
SFunf
In my laptop I have the Intel Graphics HD 4400 but I am not able to upgrade the drivers via the Driver Update Utility. Right now I have 10.18.14.4080 installed. When the Driver Update Utility searches for more recent drivers it says the latest version is 15.36.14.64.4080 but when I check the Windows Device Manager it says I still have 10.18.14.4080 installed. My laptop has already been rebooted several times. The CPU I use is an Intel Core i3 and the OS is Windows 8.1 Pro.
Thanks in advance
Kevin_M_Intel
Hello Some101,
The latest driver version for your controller is the 4080. When using the Driver update utility it will display a different driver package but at the end the driver is the same.
There is no reason to worry about this since your system is running with the latest driver version now.
Kevin M
SFunf
Hello Kevin,
Thanks for your reply.
