23801 Discussions
Cannot install Intel Driver and Support Assistant
MDani15
It isn't currently installed so there is nothing to uninstall. From the log:
[0BA0:1434][2019-05-16T10:32:11]e000: Error 0x80070005: Failed to secure cache path: C:\ProgramData\Package Cache\
[0BA0:1434][2019-05-16T10:32:11]e000: Error 0x80070005: Failed to secure cache directory: C:\ProgramData\Package Cache\
[0BA0:1434][2019-05-16T10:32:11]e000: Error 0x80070005: Failed to create completed cache path for bundle.
[0BA0:1434][2019-05-16T10:32:11]e000: Error 0x80070005: Failed to cache bundle from path: C:\Users\USERNAME\AppData\Local\Temp\{7591CE18-78D4-4262-9183-CEC99CCA85A6}\.be\Intel Driver and Support Assistant Installer.exe
[0BA0:1434][2019-05-16T10:32:11]e000: Error 0x80070005: Failed to begin registration session.
[19F0:0F38][2019-05-16T10:32:11]e000: Error 0x80070005: Failed to begin registration session in per-machine process.
[19F0:0F38][2019-05-16T10:32:11]e000: Error 0x80070005: Failed to register bundle.
AlHill
What version of Windows 10 are you running? 1809? Lower?
Even though IDSA is not installed, run this uninstaller:
https://downloadcenter.intel.com/download/28598/Intel-Driver-Support-Assistant-Uninstaller?v=t
Then, with version 1809, try again.
Note: IDSA is intended for Intel systems.
Doc
MDani15
My apologies, it is Windows 7 and the user admin account wasn't working because of UAC. Needed to run as another user so I used the domain admin. Horrible software though because it then just open a web browser as the user and you cannot install the drivers. I had to manually find them myself and update each one individually, kinda kills the ease of the utility. The old one was much better. Anyway, it is resolved...
