23821 Discussions
Cannot install driver intel UHD graphic 630
sredd3
I'm using intel i3 8100 cpu. I try download driver but it say my system no meet minimum requirements.
I use window 10 1803 version os.
I use asrock b360 pro 4 motherboard.
i try instal using intel driver support system but it no show graphics driver.
AlHill
Have you tried the driver from asrock? https://www.asrock.com/mb/Intel/B360%20Pro4/index.asp# Download ASRock > B360 Pro4
You can download the Intel driver directly from here: https://downloadcenter.intel.com/product/126790 Downloads for Intel® UHD Graphics 630
Doc
sredd3
yes Al.
I download from here but it say like in photo.
sredd3
I try asrock driver but it say same, no meet requirements of software
AlHill
Ok, attach the results of the utility I gave you the link to.
Doc
sredd3
this is utility https://downloadcenter.intel.com/product/126790 ?
I try download here but it say computer no meet minimum requirements.
sredd3
i try use this in asrock driver but it say same.
sredd3
also no display adapter show
Stefan3D
You cannot install the driver as long as the iGPU does not appear in device manager.
Activate iGPU as described at http://asrock.pc.cdn.bitgravity.com/Manual/B360%20Pro4.pdf http://asrock.pc.cdn.bitgravity.com/Manual/B360%20Pro4.pdf, page 67ff
Primary Graphics Adapter
Select a primary VGA
IGPU Multi-Monitor
Select disable to disable the integrated graphics when an external graphics card is installed.
Select enable to keep the integrated graphics enabled at all times
sredd3
thank you so much.
that worked.
