23279 Discussions
Celeron G1610 and Windows Vista: no HD Graphic Driver available
UHaer
I have a Windows Vista Home Premium installation, but are unable to find any working graphics driver for the Celeron G1610 processor.
Does anybody have an idea how to get some working drivers? The standard VGA driver of windows is really not what I was looking for 😉
Thanks for any help!
UHaer
Hello Kevin,
I am sorry, but the driver only reports, that my machine (MSI motherboard, 4GB of memory, G1610 processor) does not meet minimum requirements.
Vista has all service packs and updates till today, all drivers for the board are installed.
What do I wrong?
Thank you
Ulli
Kevin_M_Intel
Hello Ulli,
Can you please post the Dxdiag report so we can check some more information about your system?
You can do the following to get the information:
Start > Run > type in dxdiag then click OK.
When it finishes, click on the Save all information button at the bottom.
Open the text file you create.
In the notepad toolbar,
Edit > Select All
Edit > Copy
UHaer
Hello Kevin,
I did not install a Windows XP system to see if the driver runs then, so you now get the dxdiag from here.
The target still would be to be able to use the graphic adapter under Windows Vista Home. But Intel states that it will not support this OS, so I am not very confident anything will work.
System Information
Time of this report: 6/12/2013, 22:16:41
Machine name: PC
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 3 (2600.xpsp.080413-2111)
Language: German (Regional Setting: German)
System Manufacturer: MSI
System Model: MS-7788
BIOS: BIOS Date: 01/10/13 10:53:11 Ver: 04.06.05
Processor: Intel(R) Celeron(R) CPU G1610 @ 2.60GHz (2 CPUs)
Memory: 3298MB RAM
Page File: 675MB used, 4504MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0152&SUBSYS_77881462&REV_09
Display Memory: 1024.0 MB
Current Mode: 1920 x 1200 (32 bit) (59Hz)
Monitor: Plug und Play-Monitor
Monitor Max Res: 1600,1200
Driver Name: igxprd32.dll
Driver Version: 6.14.0010.5400 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 2/22/2012 12:03:52, 59392 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: Nicht zutreffend
Mini VDD: igxpmp32.sys
Mini VDD Date: 2/22/2012 12:03:48, 2521600 bytes
Device Identifier: {D7B78E66-4212-11CF-CA62-8257A8C2CB35}
Vendor ID: 0x8086
Device ID: 0x0152
SubSys ID: 0x77881462
Revision ID: 0x0009
Revision ID: 0x0009
Video Accel:
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Not Available
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Realtek HD Audio output
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0887&SUBSYS_1462D788&REV_1003
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RtkHDAud.sys
Driver Version: 5.10.0000.6873 (English)
WHQL Logo'd: Yes
Date and Size: 3/29/2013 21:42:40, 5444680 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 8000, 192000
Static/Strm HW Mix Bufs: 33, 32
Static/Strm HW 3D Bufs: 33, 32
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Description: Realtek HD Audio Input
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Microsoft MIDI-Mapper [Emuliert], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emuliert], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Maus
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Tastatur
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: ABBHOME
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x0458, 0x004C
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB-Root-Hub
| Vendor/Product ID: 0x8086, 0x1C26
| Matching Device ID: usb\root_hub20
| Service: usbhub
| Driver: usbhub.sys, 4/14/2008 00:15:38, 59520 bytes
| Driver: usbd.sys, 8/4/2004 14:00:00, 4736 bytes
+-+ Standard-USB-Hub
| | Vendor/Product ID: 0x8087, 0x0024
| | Matching Device ID: usb\class_09
| | Service: usbhub
Gameport Devices
PS/2 Devices</p...
NJano
I too am having this difficulty. I've set up a G1610 on an Asrock B75 motherboard. Intel's autoupdate app doesn't work; it just searches indefinitely. WinVista_64_152258 is the driver that shows up when searching for G1610 drivers, but I too get the "doesn't meet requirements" error message. The notes for that driver don't mention the G1610, so I assume that the driver doesn't work for that processor.
I would like to know if there is a driver for the G1610 for Vista64 or if there isn't and will never be. Vista was such a bad experience that I refuse to give Microsoft any more money for an OS, so if Intel doesn't support this processor under Vista, I'll have to switch to linux.
So, Intel experts, is there a working driver for the G1610 for Vista64?
Kevin_M_Intel
Hello Nicknack & Ulli,
The graphics controller on this processor is one of the newest ones Intel ® released (Ivy Bridge) and due to this, I am afraid to say that there are no drivers for Windows Vista for it.
Windows 7 drivers sometimes work on Windows Vista. I recommend you trying the Windows 7 driver that can be downloaded at the following link:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22842&lang=eng&OSVersion=Windows%207%20(64-bit)*&DownloadType=Drivers https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22842&lang=eng&OSVersion=Windows%207%20(64-bit)*&DownloadType=Drivers
If the driver does not work properly I recommend you contacting the motherboard system manufacturer to get their drivers.
GMaro1
I know it is an old thread but I wish to know if anything change or if you (the Intel) are willing to change it. It is a bit awkward that you can get drivers for XP, 7 and 8, and Linux, but cannot for Vista. How come? It is not rocket science to make it out from 7 or XP. It is just a driver.
Moreover, my vendor claims on it's website that Vista is supported.
http://pl.msi.com/product/mb/H61MP20_G3.html# /?div=Driver&os=Vista%2064 http://pl.msi.com/product/mb/H61MP20_G3.html# /?div=Driver&os=Vista%2064
I know this may be dependent on certain cpu's but...well on product info of IVY Bridge I did not find any information regarding the driver limitation to almost anything besides Vista. I feel fooled by you guys.
Please do something with it. 7 drivers does not work for me, as it displays error code that driver could not be loaded. I spend couple of hours to get to nowhere and may need to get gpu just because it.
One more thing, you could at least explain what is the problem on your website. Like searching for the driver on the intel website brings info "vista 32 and 64 are not supported" just imagine how many "wtf" people already made. No explanation nothing. No because of no.
I am sorry for this frustration but I am it hobbyist and never expected that kind of situation....
Please respond with some update on the driver. You are to big to make such failure, but also too big to care about your customers (afair vista still has over 3% of market, more than linux, similar to 😎
Ciao,
Greg
Ciao
