22920 Discussions
Checking for updates is getting timed out on Intel Arc Control after updating to 4672
Crybaby
Today, after upgrading my graphics driver to 31.0.101.4672, I'm facing a wired problem. Update check on Intel Arc control is getting timed out, and its not telling me if my driver is up to date or not. What can i do to fix this issue. I added a photo of the reply I'm getting after few minutes.Screenshot_2.png
genegx
Yes, this also happens with wired Ethernet connection. I am running ARC 750, and this has been happening last two updates. I am currently on update 4824.
davfel
just run intel arc update driver. happens every time.
PATHETIC
PG223
I’m having this issue, too. Steps to reproduce:
1. Use DDU to remove all Intel drivers
2. Install latest Arc driver (31.0.101.4824), Arc Control, and Intel Driver and Support Assistant
3. Restart, open Arc Control, and check for updates: no updates. Everything normal.
4. Everything normal for a day or two
5. Then after 1—2 days, Arc Control reports error as listed above and I have to start from Step 1 again to update the driver
I'm using WiFi
Hugo_Intel
Hello everyone, @Crybaby
Thank you for sharing the steps to try to reproduce this problem. There has been a new driver update version 31.0.101.4826, Can you check if the same issue happens after a regular update from 4824 to 4826?
Hugo O.
GWR52
Hi
Earlier this month used DDU and installed the latest WHQL update (ethernet) and that initially fixed the problem but have now downloaded  31.0.101.4826 and the problem is back.
It appears that you recommend that using DDU for every update to fix this issue, but if you read the notes on the DDU site it warns that you should NOT be using DDU  for every update.
I can also confirm that Control assist is running during update checks  (Active Control when on screen actually uses 7% CPU)
Win 11 Pro, AMD5700X, 32GB, ARC A750
George
Hugo_Intel
Hello everyone
I see the issue still happens after updating from 4824 to 4826, we will take a further look at this problem and check if it can be reproduced. We will post back once we have more information for you.
Hugo O.
Hugo_Intel
We did some testing in our lab and were able to replicate this issue after updating from driver 4676 to 4824, after reinstalling driver 4824 using DDU the issue would get resolved as you previously informed, however, after a regular update without using DDU to driver 4826 the error message did not pop up and the software is looking for update without an issue. Please check videos attached.
In this case, if you happen to still experience the problem after updating to driver 4826, please share with us the log files from the Intel Arc Control Software so we can take a look and see if there is anything interfering when the software is looking for an update form your side.
Hugo O.
GWR52
Hi all
Just rebooted my machine, waited for the unable to update message and I am attaching the latest arc log file as requested.
rgds
George
GWR52
Hi Hugo
This morning I changed the WHQL qualified driver setting in ARC control to ON to see if that made any difference, but of course it didn't.
The other issue which may or maybe not associated with this problem is that the settings in the ARC control front page for update actions (updates/mode/schedule/WHQL) do not stick and always reset, at some point, to the default settings.
rgds
George
PG223
I think that doing DDU and reinstalling the latest driver - 31.0.101.4826 may have worked! I'm not having connection problems and it's been over 48 hours.
Hugo_Intel
Hello Crybaby
We have received some log files from the community members so far, however, we would appreciate it if you could also share your own logs from Arc Control so we can have a bigger sample to analyze. You can use this article we previously shared to get the logs.
Hugo O.
Hugo_Intel
We reviewed this issue and continued to test this problem but we were not able to reproduce it with our latest driver 31.0.101.4826 as previously informed. At this moment our advice will be that you use Display Driver Uninstaller to reinstall the driver on your system. At the same time in case that by any chance you experience the same error message in the upcoming driver update we encourage you to open a new thread and report back the issue so we can further assist. Please note this thread will no longer be monitored.
Hug O.
vacma
PG223
Yes, I can confirm that the problem is back. Very disappointing. Please can we get this resolved?
PG223
Log files attached
Maksiks
Bump.
Same issue, no permanent fix.
EduMoreno
Bump
ghostt
Hell, just here to say to say that I'm having the same issue like everyone else on this topic. Hoping for a fix so that I don't have to download drivers manually like it's 1998
davfel
This is still a problem, even though intel's support says this is fixed. It is not fixed. please look into this. The only way that I can get this to not timeout on updates is to unload with display driver uninstall (DDU) and reload driver.
Thank you for your attention,
Dave
genegx
Confirming that this issue still exists.
BackfiringDatsun
Still an issue 11/30/2023.
Even with the latest driver.
I didn't even buy the card until mid November so my original driver version I've faced the checking for update timeout issue was way beyond the one with the alleged fix.
This is such an unusual bug.  I've been PC gaming since the 90s and have never had such an issue across countless different devices from a variety of manufacturers that all need updates.
Please devote more resources to solving this problem.  Other than this I am very happy with my A750, but this has been obnoxious enough that I've been hunting through sales for a different GPU.  Hopefully this gets solved before I spend money on another GPU.
