23688 Discussions
Chipset Identification Utility vs. Device mgr chipset ID - which correct?
The Intel® Chipset Identification Utility identifies my chipset as
http://support.intel.com/support/chipsets/sb/CS-028823.htm Intel® X48 Express Chipset
Device Manager shows Intel x38 Express chipset PCI Express Root port <!--  /* Font Definitions */  @font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-charset:1; mso-generic-font-family:roman; mso-font-format:other; mso-font-pitch:variable; mso-font-signature:0 0 0 0 0 0;} @font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:-1610611985 1073750139 0 0 159 0;}  /* Style Definitions */  p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-unhide:no; mso-style-qformat:yes; mso-style-parent:""; margin-top:0in; margin-right:0in; margin-bottom:10.0pt; margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} .MsoChpDefault {mso-style-type:export-only; mso-default-props:yes; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} .MsoPapDefault {mso-style-type:export-only; margin-bottom:10.0pt; line-height:115%;} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.0in 1.0in 1.0in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --&g(also X38 chipset to I/O port).. I am about to upgrade clean install to WIN7 and I definitely want the correct WIN7 chipset driver. Help?
Whichever one it is, don't do it manually just let the windows updates download it and it should download the correct one. Or you could manually try installing either one or both, it wont do any damage as it will only allow yiu to install one or the other.
Whether it is X38 or X48, or even X58, all have the same chipset drivers installation file.
It will only install the device ids for corresponding chipset.
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=10884&ProdId=2912&lang=eng
Anyway, if you want you can post a screenshot of the device manager showing the system devices in expanded view.
Is this a desktop or laptop?
By the way, you can always run this utility to install the unknown devices:
http://www.intel.com/support/detect.htm?iid=dc_iduu
All the best,
Kind Regards,
Aryan.
