23091 Discussions
Collage mode on two displays with different refresh rate?
THung11
I have ​two displays which refresh rate are respectively 50Hz & 60Hz.
Is it possible to use collage mode on them?
n_scott_pearson
Yes, you should be able to use collage mode. It has nothing to do with refresh rate or any other display attribute.
THung11
​Thanks for reply!
If I apply collage mode, will the refresh rate of displays remain 50Hz & 60Hz?
Or it will become the same refresh rate, then what refresh rate will it be?
The problem I encountered is I connected these displays to my NUC via HDMI and display port, but the collage mode button was disappeared and the only difference between these displays is frame rate.
n_scott_pearson
