22940 Discussions
College display feature didn't show
Pentalime
on Intel Graphic Command Center, it didn't show "College Display". even i already reinstall intel GCC.
Hardware.
Asus Vivobook flip TP470EZ
CPU: Intel Core-i5 1135G7
Ram: 8GB LPDDRX4
GPU: Intel Iris Xe / Intel Iris Xe MAX (4GB VRAM)
display: 1920x1080 60hz LCD IPS
external display: Veikk Vk1200 Pen Display (1920x1080 60hz)
DeividA_Intel
Hello Pentalime,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with the Intel Graphic Command Center.
1. Can you provide more details about your issue?
2. Where should say/appear "College Display" option?
3. Is this issue recent? Was it showing the "College Display" option before?
Deivid A.
Pentalime
at previously "before i updated my gpu driver" there's a "Combined Desktop" feature to college multiple display into one, it's available next "color format" feature, but after i updated the driver that feature is gone.
DeividA_Intel
Hello Pentalime,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
DeividA_Intel
Hello Pentalime,
Thanks for the confirmation. As a test since you mentioned the option "Combined Desktop", please try the following:
  1. Launch Intel Graphics Command Center.
  2. Click on Display.
  3. Under Connected Displays, click on the 3 dots of display 1.
  4. Click Combine Displays > Monitor 2, then select between Horizontal or Vertical.
  5. Repeat step 4 if you have more than 2 displays
Deivid A.
Pentalime
there's no "combine Display" option on 3 dots, it's only mirror Display.
here's some clip i did
DeividA_Intel
Hello Pentalime,
Thank you for the information provided
Deivid A.
DeividA_Intel
Hello Pentalime,
Thanks for your patience. In order to continue with the investigation, I will need the following:
1. Send a report from the Intel® System Support Utility (Intel® SSU):
2. Provide the Report for Intel® Graphics Drivers:
3. Just to confirm, are you using 2 monitors or just one monitor (Veikk Vk1200 Pen Display) and the laptop screen (Asus Vivobook flip TP470EZ)?
Deivid A.
Pentalime
here's the scan report file
for the third question, i need a bigger workspace for due to multitasking many apps such Premiere Pro, photoshop, and discord at same times.
soo i need 2 monitor active at once
DeividA_Intel
Hello Pentalime,
Thanks for teh report from the Intel® System Support Utility (Intel® SSU), In order to continue with the investigation, I will need the following too:
1. Provide the Report for Intel® Graphics Drivers:
2. Since you mentioned that you are using 2 external monitors. What is the brand and model name of both of them?
3. When you do a rollback of the driver, do you see the option? if so which driver version works?
Deivid A.
Pentalime
second question
it's LG monitors from 2015, i guess. it's looks really old and i can't see the model name because the label of model already disappeared.
third question
i did a few rollback and still can't found "combined desktop" feature
DeividA_Intel
Hello Pentalime,
Thanks for the report and the information provided. I will check this issue internally and get back to you with further details or if I need to confirm additional information with you.
Deivid A.
DeividA_Intel
Hello Pentalime,
Thanks for your patience. I noticed that you are using the Insider version of Windows, I recommend you try the official version of Windows with the latest drivers and test.
Based on your graphics report, you are using only one display detected built-in, bear in mind that the built display can not be used for collage mode. In Windows 10 and Windows 11, a Local Flat Panel (LFP) such as a laptop built-in display will not count towards the number of displays when using collage mode. Only an External Flat Panel (EFP) will count towards the number of displays in collage mode.
You need to use 2 external monitors connected apart from build in display in order to have the "collage display" mode option, they have to be the same model or at least have similar specs regarding resolution and refresh rate.
Deivid A.
Pentalime
Aah i see. Thanks for support and helping me 🙂
DeividA_Intel
Hello Pentalime.
Thanks for your confirmation. I am glad to know that the information shared was helpful, I will proceed to close this thread. However, you can open a new one in case you need further support or if you face any issues with our products.
Deivid A.
