23838 Discussions
Color Gamut Missing from Display Settings
CMart22
Since the Fall creators update of Windows 10. I have had issues with over saturated colors. I have since rolled back but my intel settings didn't this time. And so I don't have the Color Gamut Slider.
If anyone knows which driver had this feature it would be very helpful.
https://i.imgur.com/6tYWyRo.png https://i.imgur.com/6tYWyRo.png
Im using an Intel HD 630 on an MSI GL62M
Thank you very much for contacting the Intel Communities Team, Arkie.
Allow me to share with you that this setting was removed from the Intel® HD Graphics Control Panel since the color is adjusted now from Windows* as https://www.windowscentral.com/how-calibrate-your-pcs-monitor-windows-10 this article shows. Please try installing the http://download.msi.com/nb_drivers/vga/vga_win64%20(1)_22.20.16.4836_0x92c73879.zip graphics drivers provided by your system manufacturer to double check if this setting is available in this version.
Antony S.
CMart22
Thank you for replying. I have tried windows color calibration to no avail. however I will try the driver you provided. But I do not believe it will help me.
Hello, Arkie.
I would like to know the results of the drivers update.
Antony S.
CMart22
Thanks for the follow up. Unfortunately it did not bring back the color gamut settings I needed.
Hello, Arkie.
I have checked this with our development group and this feature can only be handle now from Windows* as previously mentioned. You can try installing rolling back to a previous Windows* version and not updating it nonetheless, we can not guarantee this option will be available.
Antony S.
MBodn
Is there any solution for this , except calibrating with a hardware?
MBodn
Im suffering from the same issue, I was able to calibrate with that slider, but it is disappeared .
