22648 Discussions
Colors washed out on secondary monitor past .4577
WiredAces
Débutant
1 022 Visites
I'm using the Intel Arc 770 GPU. The problem happens any time I install a driver version past 31.0.101.4577 (Released 7/24/2023). My primary monitor is fine, but my second monitor changes to have washed out colors or like there's too much brightness. I've attached before and after pictures to help clarify what I'm talking about.
I had the same problem with my previous GPU, which was a NVidia 1660, but I was always able to fix it by changing the dynamic output setting to full. I figure there's a similar setting for the Intel Arc, but my searching and Googling has been unable to find anything helpful.
Driver Version 4577 - Everything is fine
Anything past 4577 - Secondary monitor looks awful
0 Compliments
4 Réponses
ACarmona_Intel
Employé
998 Visites
Hello WiredAces,
Please generate an SSU report to help me further analyze important details on your system, such as the OS build number, complete model of your system, etc. To generate the SSU report, please refer to the article: How to Get the Intel® System Support Utility Logs on Windows. Please send us the generated SSU.txt file.
And for additional information, may I know the complete model of your monitors and what cable you are using?
Thank you, and have a great day ahead!
Carmona A.
0 Compliments
MUC
Contributeur émérite I
958 Visites
This information may help you:
Quantization Range Option Is Not Visible in the Intel® Graphics Control Panel or Intel® Graphics Command Center
It is also sometimes possible to adjust the setting in the monitor's On Screen Display. If you provide the information @ACarmona_Intel requested, we can be more specific.
0 Compliments
ACarmona_Intel
Employé
892 Visites
Hello WiredAces,
We are checking in with you to see if you already have the answers to our questions so we can further isolate our issue.
Thank you, and have a great day!
Carmona A.
0 Compliments
NormanS_Intel
Modérateur
849 Visites
Hello WiredAces,
Norman S.
0 Compliments
Répondre
