22945 Discussions
Command line install - "passive" switch instead of "silent"
awecomp
Having to update around 200 laptops at the moment with the latest drivers (iGFX, BT + WiFi) it'd be great if there could be the addition of the "passive" switch for command line installs, instead of a completely "silent" installer.
Just to see basic information displayed during the installation, showing the progress and a simple progress bar.
Having to manually click next, next, yes, scrolling down through the EULA etc is pretty annoying pretty quickly after about 2 laptops... 😐😂
Thanks!
Alberto_R_Intel
awecomp, Thank you for posting in the Intel® Communities Support.
Thank you very much for sharing your feedback as well. For Intel® it is very important all the comments and suggestions provided by all our clients. Based on that, I will send your observation on this matter to the proper department so they can be aware of your remarks in order to continue improving the customer's experience while using Intel® products.
Albert R.
Alberto_R_Intel
Albert R.
awecomp
Thanks for getting back so quickly, and thanks for forwarding the request on, appreciate it!
If there was also easier to find documentation (accurate and up to date) around silent/passive options that'd be a huge help.
Ideally the option to get MSI downloads for the drivers, that'd be amazing too! 😁😁
Alberto_R_Intel
awecomp, You are very welcome, thank you very much for your reply.
Sure, I will add the suggestions you just provided and send them along with the information posted previously to the proper department.
Any other inquiries or comments, do not hesitate to contact us again.
Albert R.
