23092 Discussions
Como inserir uma nova resolução de tela
Jady
Olá,
Estou com um 2º monitor que precisa de uma resolução de tela de 3440 x 1440, porém não tem essa opção nas configurações... Alguém já passou por isso?
Muito obrigada!
n_scott_pearson
This is a laptop? We are seeing quite a few reports from people whose laptops will not support a secondary monitor if its resolution is higher than the laptop's embedded display.
Jady
yes, it's a laptop (11th generation Intel Core i5-1135G7 with Intel Iris Xe Graphics and shared graphics memory)
n_scott_pearson
My suggestions are:
  1. Check BIOS Setup to see if there are any parameters related to limitations (likely not, but check anyway)
  2. Check the specs for the laptop - on the manufacturer's site - to see if they specifically say that resolution will be limited
  3. If nothing obvious in (2), contact the laptop manufacturer and ask them specifically whether this is the case.
Hope this helps,
