This is a laptop? We are seeing quite a few reports from people whose laptops will not support a secondary monitor if its resolution is higher than the laptop's embedded display.
yes, it's a laptop (11th generation Intel Core i5-1135G7 with Intel Iris Xe Graphics and shared graphics memory)
My suggestions are:
- Check BIOS Setup to see if there are any parameters related to limitations (likely not, but check anyway)
- Check the specs for the laptop - on the manufacturer's site - to see if they specifically say that resolution will be limited
- If nothing obvious in (2), contact the laptop manufacturer and ask them specifically whether this is the case.
Hope this helps,
![](/skins/images/872293744008A34B36F8ABF94A46CC66/responsive_peak/images/icon_anonymous_message.png)
Topic Options
