22974 Discussions
Compre core i3 7100, se supone que este trae HD intel 630, pero me aparece que tengo "adaptador de pantalla basico de Microsoft". ¿como lo soluciono?
RRoja
Eh seguido todos los pasos, descargue los controladores de la web y el asistente de ayuda de graficos y me sigue arrojando errores.
Datos de pc:
Procesador: i3-7100 3.9
OS: Windows 8.1 PRO x64
Placa Madre: Z270 Gaming M3
Ram: 1x8 GB - DDR4 2400MHz Ballistix Sport LT
Power Supply: EVGA 600w 80plus
Hello Rodrigonicolaz,
Thank you for contacting the Intel community.
In this case, I suggest you to manually download the latest Intel® graphics driver for the
Intel® HD Graphics 630, you can download this driver here:
https://downloadcenter.intel.com/download/26669/Graphics-Intel-Graphics-Driver-for-Windows-15-45-?product=98909 Intel® Graphics Driver for Windows* [15.45]
If for some reason you get an error downloading this driver, try installing it manually, please see how to http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html Manually Install an Intel® Graphics Driver in Windows® 10 and Windows 8*/8.1*.
I hope this can help.
Ivan.
Hello ,
I'm following on this post to ask you if your issue has been resolved or if you need further assistance.
Ivan.
RRoja
Si el problema está solucionado, CABE DESTACAR QUE PARA EL USO DE EL PROCESADOR "i3-7100" Kaby Lake de 7ma Generación solo es compatible con el sistema operativo Windows 10 por lo que si instalan otro windows no les detectará la gráfica ya que no es compatible.
Lo resolvi yo solo.
Yes, that is correct I'm sorry for not mentioning that before, you can also check on that here:
https://downloadmirror.intel.com/26669/eng/ReleaseNotes_GFX_154516.4627.pdf https://downloadmirror.intel.com/26669/eng/ReleaseNotes_GFX_154516.4627.pdf
Ivan.
