22988 Discussions
Connecting LG TV with Laptop and WiDi
RR_J
Hallo,
I am trying to connect my laptop to an LG TV with WiDi. The connection works, as I see the LG TV in MyWiFi dashboard and the TV sees my laptop and I am able to connect both devices. However I am not able to get an output from laptop to TV. It is said that you have to rightklick on the desktop of the laptop, choose intel graphics and set "output to" to the TV. I don´t have this option, there is no TV listet. There are only the two other monitors in the list which are connected to my laptop, one via HDMI and one via D-Sub. I use Intel HD 4600 graphics. Is it a matter of the graphics card or did I miss something?
Kind regards,
Nordberg
Hello Nordberg,
I noticed that you created two threads for the same issue, but you marked this one
https://communities.intel.com/thread/107225 https://communities.intel.com/thread/107225 as correct. So, just to confirm; were you able to fix the issue?
If there is something I can help you with let me know.
Amy.
Hello /thread/107189 Nordberg,
I hope that everything is working fine with your WiDi set up and if there is something I can help you with let me know.
Amy.
