22643 Discussions
Conserver les proportions ou passer en plein ecran absent des que ce n est plus sur l affichage intégré. Comment faire pour avoir ces options sur un ecran externe svp?
Bonjour,
Sur l affiche intégré je peux passer en plein ecran ou conserver les proportions ou encore centrer l image. Mais quand je me branche sur un ecran externe je n ai pas ces options, ce qui fait que j ai une petite image entouré d'une bordure noire. Je peux seulement centrer l image ou conserver la mise a l echelle de l écran.
Mon matériel, pc tablette 2 en 1 thomson Hero10.32B, hd graphics Intel 3eme génération avec windows 10.
Pourriez vous m aider svp? Merci.
I would like to have additional information about your system configuration and graphics drivers version. Please run the following utility and attach the results.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Intel® System Support Utility
In order to attach files, make sure you select the "Advanced Editor" option in the top right of your reply window. You will then be presented with an attach file dialogue at the bottom of the reply.
Allan.
Sorry I don't speak very well English.
Thanks you Allan for your reply.
Here is the result.
Thank you for the report. It is really helpful. I was able to identify the processor model and the graphics controller and also, your current graphics drivers version.
Please try testing the following driver version https://downloadcenter.intel.com/download/25977/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-33-?product=81499 4425
Hope this information is helpful.
Please do let me know if you need further assistance with your Intel product, I will be glad to assist you.
Allan.
After install the new driver, already the same problem for my external screen. I can only center the screen. For my integrated screen everything is ok I can scale in full screen with and without using proportion.
Thanks for the information.
Please bear in mind you have a tablet computer that may require customized drivers.
Make sure you are not using video cable adapters.
When installing Intel® graphics drivers from the Intel page, you will install generic drivers that may not have proper multi-monitor functions.
Try checking with the computer manufacturer for custom drivers for your tablet model.
http://www.thomsoncomputing.eu/book.html http://www.thomsoncomputing.eu/book.html
Allan.
Were you able to contact your computer manufacturer for custom drivers?
Allan.
Yes i do but my manufacturer said they don't have some drivers for my computer...
Thank you for your help Allan.
