23525 Discussions
Crashing When loading up from a save file from Starfield
NuLeaf
Before the recent updates from both Bethesda and Intel, the game crashed fairly often. I was hoping that i could wait until newer updates came out from either. Since then, i cannot even load from a save file. The game will now immediately crash. I managed to find the crash log found in User/AppData/Local/Starfield, and this is what it says:
Current Render Pass:Transparency RenderPass
Pseudo-Stack:
CmdDispatch (End)
CmdDispatch (Begin)
Incomplete Operations:
LayeredEffect-MO_MBOIT_FORWARD-NOEMISSIVE-SUPPORTS_FLOW-USE_GI_FALLBACK-SHADOW_FILTERING_MEDIUM (0x00000000E4001009)
CmdExecuteIndirect (Begin)
CmdExecuteIndirect (End)
Checkpoint Data:
Checkpoint Queue 1 (Type "GPU Graphics"):
BeginCmd
ParticlesMomentsHalfRes RenderPass
ProduceParticleTargetsHalfRes RenderPass
Transparency
Prepare
GPUCulling_Meshlet-PREPARE_ARGS (0x000000000400FFD4)
CmdDispatch (Begin)
CmdDispatch (End)
CmdDispatch (Begin)
CmdDispatch (End)
CmdDispatch (Begin)
CmdDispatch (End)
CmdDispatch (Begin)
CmdDispatch (End)
CmdDispatch (Begin)
CmdDispatch (End)
------------Complete Operations Above Here------------
------------Started Operations Above Here------------
Checkpoint Queue 2 (Type "GPU Compute"):
Checkpoint Queue 3 (Type "GPU Copy"):
Currently, my system info is:
Windows 11
Intel Arc A770 16GB
16GB DDR4
Intel 12th Gen 12500k CPU
The game was installed onto a SSD and from Xbox Games on PC. I hope this can be resolved quickly, as i cannot even play the game anymore. I have attached the files where this error log was from below. Thank You.
EDIT: Now i am getting more issues. The game will not even go as far as the main menu before crashing, and I am now experiencing issues outside of Starfield. When i load YouTube on my browser for example, It is missing graphics from the webpage and also getting occasional artifacts. I ran auto updates on windows and it wants me to revert to an older Intel driver (31.0.101.4577). I installed it and now my browsers are stable but I'm afraid i cant even run Starfield. What is going on??? This update has caused more issues than it has fixed it seems.
ekztal
I just updated to driver version 31.0.101.4824 and I get the same error (0x00000000E4001009).  This is the 3rd driver update I've installed since getting Starfield.  It's gone from not booting at all, and sucking up all 32GB of RAM to somewhat playable and crashing every 5 minutes to the latest where it crashes when loading save files.
NuLeaf
This is exactly what's happening to me too. Since I've updated to the latest drivers from Intel on the 13th and updated from Bethesda on the same day, the game is literally unplayable.
NuLeaf
Andres_Intel
Hello everyone,
Thank you for posting on the Intel®️ communities. As a gamer I understand is very frustrating when a game does run, in this case like Starfield with your Intel® Arc™ A770 Graphics (16GB), I am more than happy to help you.
For the browser issue to keep this thread organized and help you in the best way, please open another thread for this question.
To understand the issue in the best way, please answer the following questions:
Andres P.
NuLeaf
Hey Andres,
I cannot attach the report in this thread because its a HTML, and that file type is not supported in these forums. As for the other driver, where can i find the download link?
Andres_Intel
Hello NuLeaf,
Thank you for your response, I am sorry to hear that you were not able to attach Intel® SSU.
To attach it please follow the steps below as it should generate a .txt file:
  1. Once it is downloaded. Scan: Check the box Everything.
  2. Click Scan.
  3. Review: When finished scanning, click Next.
  4. Click Save.
Please let me know the results.
Andres P.
NuLeaf
I have attached the new system report.
I tried installing the older driver (31.0.101.4577), and the game would not even boot. I noticed in my task manager that it was taking up 100% of my CPU memory.
When i installed the latest driver that has been released on the 18th (31.0.101.4826) The game had launched and also manages to load a save file. However, this only lasts until you arrive at HUB locations in game (new atlantis for my specific crash) or when you arrive at a loading screen of any sort.
Andres_Intel
Hello NuLeaf,
Thank you for your reply and for sharing the information, that helps me to have a better understanding.
Intel is currently investigating this issue, we are working really hard to solve it as soon as possible.
Please let me know if you have further questions.
Andres P.
Andres_Intel
Hello NuLeaf,
Were you able to check the previous post? Remember Intel is investigating this issue.
Andres P.
NuLeaf
It sounds like you guys don't really have a solution as of yet, so i wouldn't considered this resolved. If anything changes ill update the forum.
Andres_Intel
Hello NuLeaf,
Thank you for your answer.
We will appreciate it if you post any updates on the forum, for now, please provide us with the logs that are generated for the crash, this will help us with the investigation.
Andres P.
NuLeaf
Here is the most recent crash log, with the latest starfield update.
Andres_Intel
Hello NuLeaf,
Thank you for sharing the logs of the crash.
I will add them to our investigation to find the fix as soon as possible. I will keep this thread open, for the moment, in case we need more information from you. As soon I have further details I will let you know.
Andres P.
Andres_Intel
Hello NuLeaf,
Thank you for your time.
We still working on the investigation, no we are working on the issue reproductions, and we will see if we have the same results, the information you provided has helped a lot.
Andres P.
NuLeaf
An update on the recent driver update (31.0.101.4885)
Yesterday i managed to have a 3 hour game session playing Starfield, with no crashed whatsoever! When loading into different areas of the game, it seamlessly loaded, no signs of frame drops, and no graphical issues what so ever!
It may be too soon to speak, since this update isn't a WHQL Certified update, but i believed the issue to be resolved. Thanks!
Andres_Intel
Hello NuLeaf,
Thank you for your patience and for keeping us informed.
We have completed the issue reproduction and the issue was present with driver 31.0.101.4826, actually, I was going to recommend updating the driver to version 31.0.101.4885 I am happy to hear that it fixed the issue.
We will close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andres P.
