20776 Discussions
Ctrl + Alt + F8 affects my monitors despite Intel HD Graphics Control Panel hot keys being disabled.
SSean
I press Ctrl + Alt + F8 and my monitors connected to my motherboard built-in GPU are disabled. Where are the settings for this? The hot key section of Intel HD Graphics Control Panel does not include this key combination.
OS: Win 10 Pro 64-bit
Mainboard: ASUS Z170 Pro Gaming, board revision 1.04, BIOS v3501
CPU: Intel i7 6700, Stock HSF, Undervolt Offset -0.1 V, VCCIO 1.09 V, System Agent 1.05 V, LLC 4 (all core enhancement DISABLED)
RAM: Corsair LPX Vengeance 2x8GB DDR4-3000 (CMK16GX4M2B3000C15), XMP
Graphics: Gigabyte NVIDIA GeForce GTX 950 w/ 2 GB
Sys Drive: Samsung Evo 750 SSD, 250 GB
Data Drives: OCZ Vertex 2 SSD, 60 GB; WDC WD1002FAEX-00Y9A0, ~1 TB; WDC WD2003FZEX-00Z4SA0, ~2 TB; WDC WD2002FAEX-00MJRA0, ~2 TB; RAID 0, ~300 GB [Maxtor 6B160MO x 2]
PCI-E SATA expansion: IOCREST SATA III 4-port PCI-e (SI-PEX40064)
PSU: XFX TS 750W (P1-750S-NLB9)
Bluetooth: Parani UD100 Bluetooth USB Adapter
Monitor: LG 21.5" W2246S-BF 16:9 Wide LCD Monitor 1920x1080 5ms
Logitech G500 mouse, K120 keyboard.
Hello THX1138,
Thank you for bringing this matter to the Community.
The combination of Ctrl + Alt + F8 will restore the graphics defaults. I checked my Intel® HD Graphics Control Panel and Hot Key is present there, see below;
So, if you press this key combination it is expected for the monitors to be disabled since it is taking you to the default settings.
Amy C.
SSean
Okay, thanks. Why then, isn't the hot key disabled with the others when I select 'Disable Hot Keys'? I want to assign Ctrl + Alt + F8 to another function in another program but I want to do this without disabling my monitors each time. Could this please be taken as a feature request? Thanks.
As you can confirm in the Intel® HD Graphics Control Panel this combination is set as default, but of course I will send your feature request to the proper department. Hopefully it can be considered for future driver releases.
Amy C.
