23788 Discussions
Custom Resolution on Intel HD 4600
NLars1
I recently bought a Dell XPS 27" All In One machine. I have a second 27" monitor hooked up via HDMI (the only output this PC has), and I cannot for the life of me get it to display at 2560x1440. I know that this is supposedly a limitation of HDMI, but I have 4 other Dell 27" AIO machines running them over HDMI. What I had to do was set a custom resolution of 2560x1440 29MHZ and all works great. The 4 machines that are currently working use the Intel HD Graphics 4000 driver and have the option for a custom resolution. Is there any way I can get this to work on the 4600?
MSchm21
Valued Contributor I
Go into the drivers folder, there is a file called CustomModeApp.exe. You can change the resolution there.
MSchm21
NLars1
Perfect. That worked! Thank you very much.
LT1
I wanted to add for those looking for more specifics: CustomModeApp.exe is in the 'Graphics' folder of the latest Intel video drivers. It also gets placed in C:\Windows\System32 when the driver is installed.
VKorp
Hey guys,
I created a custom resolution with the same program as listed above but how do I select the custom resolution to show up? I just created a custom resolution but I can't find the option to enable it. How do I do this? Thanks in advance!
EstebanA_C_Intel
Hello:
I would like you to check this thread that is related to this.
Also, make sure you are using the latest driver available.
Esteban C
VKorp
Sorry for my late response Esteban,
But I think it's just not possible to enable custom resolutions on my computer. BTW I have a macbook pro with bootcamp so may be that's the issue. And I read your thread and they didn't tell how to enable the custom resolution. As noted above, I can create one but I don't see an option to apply it. How can I apply it? Does somebody else know?
Thanks for your response
EstebanA_C_Intel
Hello, Vincentjuhhh:
Apple has requested that all questions regarding Apple systems and software be addressed directly with Apple support. I recommend checking the links below for troubleshooting assistance on your Apple computer:
http://www.apple.com/support/imac/intel/ http://www.apple.com/support/imac/intel/
http://www.apple.com/support/mac/n http://www.apple.com/support/mac/n
https://www.apple.com/support/macbook/ https://www.apple.com/support/macbook/
http://www.apple.com/support/macmini/ http://www.apple.com/support/macmini/
Here you can find the generic drivers from Intel®, but I cannot assure you that they are going to work properly while using them in an Apple device.
Just make sure you select the correct OS and version (32/64-bit): https://downloadcenter.intel.com/product/81496/Intel-HD-Graphics-4600-for-4th-Generation-Intel-Core-Processors Drivers & Software
Esteban C
00SoCRaT00
please help me i can't find this file CustomModeApp
