23807 Discussions
Custom Resolution
GEN1
When I try to add a custom resolution in IGCC I get the "Unable to add settings . Reason: Mode not supported." I also tried CRU, but nothing gets added to the mode list.
Why is this?
I just got an awsome Lacie Electron Blue II  CRT monitor and a top quality VGA cable. Running on HP Prodesk with Intel UHD Graphics 630.
The monitor can output 2046x1536@80Hz.
The resolutions and Hz I can choose is from the list is just sad.
MUC
Honored Contributor I
QuickSpecs - HP ProDesk 400 G4 DM / AIO - G5 MT / SFF
This is not a generic Intel implementation. Please use the drivers that HP provides. This should allow you to output what HP says it can via VGA. If not, you will need to contact HP support.
GEN1
I have downloaded the driver from HP. I got a HP ProDesk 400 G5 Desktop Mini PC (6GE67AV).
MUC
