23727 Discussions
Custom resolution > maximum bandwidth
APart1
102 987 Visites
I have a laptop with an Intel HD 4400 and I'm trying out custom resolutions for the internal display (1920x1080). Don't know what it supports, but I'd like to find out.
The default display modes already include 60Hz and 40Hz. I want to try 48Hz and 50Hz to make movie watching smoother, but whatever I choose, I get "The custom resolution exceeds the maximum bandwidth capacity.". This is obviously not true, as I'm already using 60Hz. I'm only trying modes that are between the already existing and working modes.
What to do?
0 Compliments
26 Réponses
Kevin_M_Intel
Employé
67 921 Visites
Hi ajp_anton,
The graphics controller in your computer supports higher resolutions than the one you are trying to achieve. As an example, it can go up to 2560x 1600 when using Display port but this depends on the monitor supported resolutions and the limitations set by the computer manufacturer.
Even though the monitor supports resolutions at 60 Hz or 40Hz it does not mean that can support 50Hz. You can check what resolutions can support the internal monitor on your system by doing the following steps:
  1. Open Intel Graphics and Control panel.
  2. Go to Options and select Information Center under the drop down menu.
  3. Click Save.
By doing this, you will have a document with the supported resolutions by your monitor and so you will know what resolutions and hertz can be used with your system. It is also important to mention that we as Intel® provide the hardware to the computer manufacturers and they will design and create their systems with their specifications meaning that they can also set limitations such as the supported resolutions.
0 Compliments
APart1
67 920 Visites
The Information Center doesn't give reliable information for adventurous users. I have two other monitors - laptop and external - that only list 60Hz, but they work fine with both 50 and 48Hz if you "force" it. The monitor manufacturers have no reason to list or officially support "exotic" display modes, they just sometimes work with certain models.
I want to see what this one's capable of. If 50Hz doesn't work, I'd expect a blank screen because of limitations in the display, but "exceeds the maximum bandwidth" is simply wrong.
Kevin_M_Intel
Employé
67 920 Visites
Hello ajp_anton,
Can you please post your Graphics report here? Go to Intel® Graphics and Control Panel > Options > information Center > Save.
0 Compliments
APart1
67 921 Visites
0 Compliments
Kevin_M_Intel
Employé
67 922 Visites
Hi ajp_anton,
I am afraid I do not have access to that link. Please post your graphics report here.
0 Compliments
APart1
67 922 Visites
Intel(R) HD Graphics 4400
Report Date: 10/16/2013
Report Time[hh:mm:ss]: 22:56:47
Driver Version: 9.18.10.3257
Operating System: Windows 7 Service Pack 1(6.1.7601)
Default Language: Swedish (Sweden)
Installed DirectX* Version: 11.0
Supported DirectX* Version: 11.0
Shader Version: 5.0
OpenGL* Version: 4.0
Physical Memory: 8105 MB
Processor: Intel(R) Core(TM) i5-4200U CPU @ 1.60GHz
Processor Speed: 2294 MHz
Vendor ID: 8086
Device ID: 0A16
Device Revision: 09
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 4400
Video BIOS: 2171.1
Current Graphics Mode: 1920 by 1080
* Devices Connected to the Graphics Accelerator *
Active Notebook Displays: 1
* Built-in Display *
Monitor Name: Generic PnP Monitor
Display Type: Digital
Connector Type: Embedded DisplayPort
Serial Number: MEI96A2
Gamma: 2.2
DDC2 Protocol: Supported
Device Type: Built-in Display
Maximum Image Size:
Horizontal: 11.42 inches
Vertical: 06.69 inches
Monitor Supported Modes:
1920 by 1080 (40 Hz)
1920 by 1080 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Not Supported
Raw EDID:
00 FF FF FF FF FF FF 00 34 A9 A2 96 00 00 00 00
FF 17 01 04 A5 1D 11 78 02 95 21 A6 53 53 98 25
0B 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 02 3A 80 58 71 38 0D 40 2C 06
92 00 58 C1 10 00 00 1E 02 3A 80 58 71 38 30 42
2C 06 92 00 58 C1 10 00 00 1E 00 00 00 FD 00 26
3E 40 43 0F 01 0A 20 20 20 20 20 20 00 00 00 FC
00 56 56 58 31 33 46 30 30 39 47 30 30 0A 00 0A
* Other names and brands are the property of their respective owners. *
0 Compliments
Kevin_M_Intel
Employé
67 922 Visites
Hi ajp_anton,
Thanks for the information.
Based on the graphics report you posted, these are the Monitor Supported Modes:
Using a different mode than the ones above, may not work as expected or in the worst case the monitor can be damaged.
0 Compliments
APart1
67 923 Visites
Yes, that doesn't really do me anything, as I already know 40Hz and 60Hz are the officially supported modes, and I can read those from the report myself.
I have an external screen that is supposed to work only in 60Hz according to that same report, but it does in fact support 48Hz and 50Hz just fine if you force them and movies look smoother than ever. Another laptop also works in 24,25,48,50Hz in addition to the lonely officially supported 60Hz.
I'm obviously willing to take the "risk" of using 48 and 50Hz on my display. Why do the drivers not let me, and why do I get an incorrect error message?
0 Compliments
Kevin_M_Intel
Employé
67 923 Visites
Hello ajp_anton,
I understand the fact that the monitor can support a different resolution if it is forced to but the driver will provide the supported monitor resolutions only as we cannot guarantee the correct functionality if the hardware is forced.
My Best recommendation is to use the default settings the system provides you to void damaging the hardware.
0 Compliments
MRoge8
67 923 Visites
Hey Kevin,
There's definitely a bug in the Intel HD Graphics Control Panel. Here are the reproduction steps:
  1. Dell E7450 laptop with Intel HD Graphics 5500 (Graphics report below)
  2. DELL UP3214Q monitor.
  3. HDMI cable (don't know the version, but probably 1.3)
  4. In Ubuntu 14.10 this combo runs at 3840x2160 @ 30Hz.
  5. In Windows 7 64-bit, try to add the above as a custom resolution in the Intel HD Graphics Control Panel.
The error is:
This is obviously bogus because the very same hardware does output that resolution in Ubuntu.
More interestingly, after using Ubuntu for a few days, when I booted back to Windows, the 4K resolution was available. Unfortunately that only lasted until the next reboot, after which the "boot in Ubuntu" trick no longer worked - super, super frustrating. I've also asked http://superuser.com/questions/957222/enable-4k-3840-x-2160-resolution-on-windows-7-with-intel-hd-graphics-card on StackExchange, but nobody had a solution.
I paid almost $2000 for this monitor so I really hope that you guys push out a fix as soon as possible.
Graphics report below.
Intel(R) HD Graphics 5500
Report Date: Friday, August 14, 2015
Report Time [hh:mm:ss]: 00:04:37
Driver Version: 10.18.14.4099
Operating System: Windows* 7 Professional (6.1.7601)
Default Language: English (United States)
Physical Memory: 16290 MB
Vendor ID: 8086
Device ID: 1616
Device Revision: 09
Video BIOS: 1032.15
Current Resolution: 1920 x 1080
Processor: Intel(R) Core(TM) i5-5200U CPU @ 2.20GHz
Processor Speed: 2194 MHz
Processor Graphics in Use: Intel(R) HD Graphics 5500
Shader Version: 5.0
OpenGL* Version: 4.3
OpenCL* Version: 2.0
* Microsoft DirectX* *
Runtime Version: 11.0
Hardware-Supported Version: 11.0
* Devices connected to the Graphics Accelerator *
Active Displays: 2
Gamma: 2.2
Maximum Image Size
Horizontal Size: 12.2 inches
Vertical Size: 6.69 inches
Supported Modes
1920 x 1080 (60p Hz)
1920 x 1080 (48p Hz)
Raw EDID:
00 FF FF FF FF FF FF 00 06 AF 3D 13 00 00 00 00
22 17 01 04 95 1F 11 78 02 87 E5 A4 56 50 9E 26
0D 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 14 37 80 B8 70 38 24 40 10 10
3E 00 35 AD 10 00 00 1A 10 2C 80 B8 70 38 24 40
10 10 3E 00 35 AD 10 00 00 1A 00 00 00 FE 00 4D
31 57 48 56 81 42 31 34 30 48 41 4E 00 00 00 00
00 00 41 21 9E 00 00 00 00 0A 01 0A 20 20 00 71
* Digital Television *
Serial Number: [redacted]
Gamma: 2.2
Connector Type: DisplayPort
Device Type: Digital Television
Maximum Image Size
Horizontal Size: 27.56 inches
Vertical Size: 15.35 inches
Supported Modes
640 x 480 (60p Hz)
640 x 480 (75p Hz)
720 x 400 (70p Hz)
720 x 480 (60p Hz)
720 x 480 (60i Hz)
720 x 576 (50p Hz)
720 x 576 (50i Hz)
800 x 600 (60p Hz)
800 x 600 (75p Hz)
1024 x 768 (60p Hz)
1024 x 768 (75p Hz)
1152 x 864 (75p Hz)
1280 x 1024 (60p Hz)
1280 x 800 (60p Hz)
1280 x 1024 (75p Hz)
1280 x 720 (50p Hz)
1280 x 720 (60p Hz)
1600 x 1200 (60p Hz)
1680 x 1050 (60p Hz)
1920 x 1200 (60p Hz)
1920 x 1080 (50i Hz)
1920 x 1080 (50p Hz)
1920 x 1080 (24p Hz)
1920 x 1080 (60i Hz)
3840 x 2160 (24p Hz)
3840 x 2160 (30p Hz)
3840 x 2160 (25p Hz)
Standby Mode: Supported
Suspend Mode: Supported
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 10 AC 92 40 50 39 39 32
14 18 01 03 80 46 27 78 EA 73 E0 A3 53 36 B6 26
0D 51 53 A5 4B 00 81 00 B3 00 D1 00 71 4F A9 40
81 80 D1 C0 01 01 04 74 00 30 F2 70 5A 80 B0 58
8A 00 BA 88 21 00 00 1E 00 00 00 FF 00 4B 33 52
39 30 34 35 43 32 39 39 50 0A 00 00 00 FC 00 44
45 4C 4C 20 55 50 33 32 31 34 51 0A 00 00 00 FD
00 1D 4B 1F 8C 1E 00 0A 20 20 20 20 20 20 01 EE
02 03 23 B1 50 90 05 04 03 02 07 16 01 06 11 12
15 13 14 1F 20 6D 03 0C 00 10 00 00 3C 20 00 60
03 02 01 04 74 00 30 F2 70 5A 80 B0 58 8A 00 BA
88 21 00 00 1E 02 3A 80 18 71 38 2D 40 58 2C 25
00 BA 88 21 00 00 1E 01 1D 80 18 71 1C 16 20 58
2C 25 00 BA 88 21 00 00 9E 01 1D 00 72 51 D0 1E
20 6E 28 55 00 BA 88 21 00 00 1E 8C 0A D0 8A 20
E0 2D 10 10 3E 96 00 BA 88 21 00 00 18 00 00 14
Non applicable
67 924 Visites
Hi Dandv,
The latest graphics driver for Intel® HD Graphics 5500 for 5th gen processors is version 15.36.24.64.4264.
https://downloadcenter.intel.com/product/86210/Intel-HD-Graphics-5500-for-5th-Generation-Intel-Core-Processors Intel® Download Center
Now, the graphics application provides with the official resolution of the monitor according to the Extended display identification data (EDID). High resolutions need high quality video cables.
HDMI 1.4a and Displayport 1.2
Miguel C
0 Compliments
MRoge8
67 924 Visites
Hi Miguel,
I'm not sure how that answers my bug report.
I can't install the Intel driver you linked to on my DELL laptop because it's not an OEM driver. I get this error: "The driver being installed is not validated for this computer. Please obtain the appropriate driver from the computer manufacturer."
As I mentioned, the exact same hardware configuration worked fine in Ubuntu.
0 Compliments
Non applicable
67 924 Visites
Hi dandv,
In your case, it will be necessary to wait for a new driver from Dell. I apologize for the inconvenience.
Intel is following Windows 10 graphics issues. Please review the tread below and fulfill the form.
Re: -NEW- Intel® Iris™, Iris™ Pro, and HD Graphics Production Driver for Windows* 10 64-bit 15.40.4.64.4256
/message/321854# 321854 https://communities.intel.com/message/321854# 321854
See post # 93
0 Compliments
MRoge8
67 925 Visites
The DELL driver is a fork of the Intel one. Is it possible that the buggy "exceeds maximum bandwidth" message comes from the Intel driver codebase?
0 Compliments
ARock
Débutant
67 925 Visites
Hi there,
I was wondering about these issues myself, and I noticed you said the latest was Intel graphics 5500.
I'm using an MSI Apache GE62 2QF with these specs:
Intel(R) HD Graphics 5600
Report Date: Sunday, August 30, 2015
Report Time [hh:mm:ss]: 2:07:57 AM
Driver Version: 10.18.15.4256
Operating System: Windows* 10 Pro Insider Preview (10.0.10240)
Physical Memory: 16299 MB
Vendor ID: 8086
Device ID: 1612
Device Revision: 0A
Graphics Output Protocol (GOP) Version: 5.5.1032
Processor: Intel(R) Core(TM) i7-5700HQ CPU @ 2.70GHz
Processor Speed: 2694 MHz
Processor Graphics in Use: Intel(R) HD Graphics 5600
Shader Version: 5.0
Runtime Version: 12.0
Hardware-Supported Version: 11.1
Active Displays: 1
Gamma: 2.2
Maximum Image Size
Horizontal Size: 13.39 inches
Vertical Size: 7.48 inches
Supported Modes
Raw EDID:
00 FF FF FF FF FF FF 00 4C 83 4C 32 00 00 00 00
00 17 01 04 95 22 13 78 0A CE 85 9E 5B 4C 94 26
-------Not only can I not find the i7-5000 mobile processor on intel's site, a search for intel HD graphics 5600 yields no results either.
In fact, running the intel driver update utility, it is showing that my current driver is a higher release than the "Latest driver".
HOW IS THAT POSSIBLE?! Am I using a driver from the future?
Moreover, there's a big shiny sticker on my laptop that says "Ultra HD 4k display"
..........but my intel graphics options do the "exceeds bandwidth" no matter what I try. Honestly, I'm totally flabbergasted at all of these things. How is my driver beyond latest? How am I locked into less resolution than my hardware claims? What is this madness?
-EDIT: and my runtime is higher than my hardware supported directx version. I'm quite confused.
0 Compliments
Cesar_B_Intel
Employé
67 925 Visites
Hello Coldspark,
Please try using the Intel® HD graphics 5600 from here https://downloadcenter.intel.com/download/25274/Intel-Iris-Iris-Pro-and-HD-Graphics-Production-Driver-for-Windows-7-8-1-10 Intel® Download Center
and let me know of the results.
Additionally, in regards to the Intel® HD Graphics driver please refer to the Detailed Description here: https://downloadcenter.intel.com/download/25274/Intel-Iris-Iris-Pro-and-HD-Graphics-Production-Driver-for-Windows-7-8-1-10 Intel® Download Center
"This document provides information about Intel's Graphics Driver for:
- 6th Generation Intel® Core™ Processors, Intel® Core™ M, and related Intel® Pentium® Processors with Intel® HD Graphics 510, 515, 520, 530
- 5th Generation Intel® Core™ Processors with Intel® HD Graphics 5500, 5600, 6000, Intel® Iris™ Graphics 6100, Iris Pro Graphics 6200
and select Pentium®/ Celeron® Processors with Intel® HD Graphics Intel® Core™ M with Intel HD Graphics 5300
- 4th Generation Intel® Core™ Processors with Intel® HD Graphics 4200, 4400, 4600, 5000, Intel® Iris™ Graphics 5100 and Intel® Iris™ Pro Graphics 5200 and select Intel® Pentium®/Intel® Celeron® Processors with Intel® HD Graphics"
Caesar B.
0 Compliments
MRahm8
Débutant
53 312 Visites
Has anyone got this problem solved?
I did the intel information file, and I see that the higher resolution is supported, so why is it that it doesn't show on the options?
Intel(R) HD Graphics 4600
Report Date: Thursday, July 21, 2016
Report Time [hh:mm:ss]: 9:59:47 AM
Driver Version: 20.19.15.4390
Operating System: Windows* 10 Pro (10.0.10586)
Physical Memory: 16289 MB
Vendor ID: 8086
Device ID: 0416
Device Revision: 06
Video BIOS: 2178.15
Processor: Intel(R) Core(TM) i7-4710MQ CPU @ 2.50GHz
Processor Speed: 2494 MHz
Processor Graphics in Use: Intel(R) HD Graphics 4600
Shader Version: 5.0
OpenCL* Version: 1.2
Active Displays: 2
Inactive Displays: 1
Gamma: 2.2
Maximum Image Size
Supported Modes
Serial Number: 006TK3XY00601
Gamma: 2.2
Maximum Image Size
Horizontal Size: 20.08 inches
Vertical Size: 11.42 inches
Supported Modes
640 x 480 (60p Hz)
640 x 480 (75p Hz)
720 x 400 (70p Hz)
720 x 480 (60p Hz)
720 x 576 (50p Hz)
720 x 480 (60i Hz)
720 x 576 (50i Hz)
800 x 600 (75p Hz)
800 x 600 (60p Hz)
832 x 624 (75p Hz)
1024 x 768 (75p Hz)
1024 x 768 (60p Hz)
1280 x 720 (60p Hz)
1280 x 720 (50p Hz)
1400 x 1050 (60p Hz)
Raw EDID:
00 FF FF FF FF FF FF 00 22 64 7F 22 01 01 01 01
06 14 01 03 80 33 1D 78 EA DC 55 A3 59 48 9E 24
11 50 54 A5 6B 00 81 80 A9 40 90 40 B3 00 01 01
01 01 01 01 01 01 02 3A 80 18 71 38 2D 40 58 2C
45 00 FD 1E 11 00 00 1E 00 00 00 FC 00 48 61 6E
6E 73 2E 47 20 48 48 32 33 31 00 00 00 FD 00 38
4B 18 53 11 00 0A 20 20 20 20 20 20 00 00 00 FF
00 30 30 36 54 4B 33 58 59 30 30 36 30 31 01 98
02 03 29 F1 23 09 7F 07 4F 90 01 02 03 06 07 15
16 11 12 13 04 05 14 1F 83 01 00 00 6C 03 0C 00
10 00 B8 2D C0 01 01 01 01 8C 0A D0 8A 20 E0 2D
10 10 3E 96 00 FD 1E 11 00 00 18 8C 0A D0 90 20
40 31 20 0C 40 55 00 FD 1E 11 00 00 18 01 1D 80
18 71 1C 16 20 58 2C 25 00 FD 1E 11 00 00 9E 01
1D 80 D0 72 1C 16 20 10 2C 25 80 FD 1E 11 00 00
9E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 3E
* Digital Display *
Serial Number: 0000000000000
Gamma: 2.2
Device Type: Digital Display
Maximum Image Size
Horizontal Size: 23.62 inches
Vertical Size: 13.39 inches
Supported Modes
640 x 480 (60p Hz)
640 x 480 (75p Hz)
720 x 400 (70p Hz)
800 x 600 (60p Hz)
800 x 600 (72p Hz)
800 x 600 (75p Hz)
1024 x 768 (60p Hz)
1024 x 768 (75p Hz)
1152 x 864 (75p Hz)
1280 x 720 (60p Hz)
1440 x 900 (60p Hz)
2560 x 1440 (60p Hz)
Raw EDID:
00 FF FF FF FF FF FF 00 08 34 00 27 00 00 00 00
34 17 01 04 80 3C 22 78 3A 6F B1 A7 55 4C 9E 25
0C 50 54 A5 CB 00 71 4F 81 C0 81 80 95 00 B3 00
D1 C0 01 01 01 01 56 5E 00 A0 A0 A0 29 50 30 20
35 00 55 50 21 00 00 1E 00 00 00 FF 00 30 30 30
30 30 30 30 30 30 30 30 30 30 00 00 00 FD 00 17
4C 0F 63 19 00 0A 20 20 20 20 20 20 00 00 00 FC
00 4D 4F 4E 49 54 4F 52 2D 44 56 49 0A 20 00 A1
0 Compliments
MHirs1
67 925 Visites
I'm also running into this problem. The custom resolution dialog only allows me to enter display modes that the display already reports to the graphics chip. Anything else and I get the message about "exceeds bandwidth". The above interaction was one of the most infuriating things I've read - kevin_intel couldn't be more obtuse. Hello! If I can only use the modes reported by the display why is there a custom mode dialog? There's clearly a bug in the code that adds custom modes, or at least the wrong error is reported. It's plainly clear that the mode I am entering does not exceed the bandwidth of anything -- it uses less bandwidth than a supported (working) mode!
ahmadrizqi
Débutant
42 244 Visites
Same here, I have a 1600x900 monitor which is 60Hz at stock and can be overclocked to 110Hz using 3rd party software without any problem.
WhatsApp Image 2022-03-16 at 16.29.37 (1).jpegWhatsApp Image 2022-03-16 at 16.29.37 (1).jpeg
But when trying to add 1600x900 @60Hz (which is exactly the stock specification this monitor came with) under Intel's own custom resolution, it says "The custom resolution exceeds the maximum bandwidth capacity"
I'm looking to buy a new CPU with iGPU but considering this has not been fixed for years, Intel CPUs are excluded from the list.
0 Compliments
APana3
Débutant
67 925 Visites
Did anybody manage to bypass the "exceed bandwidths" problem somehow? I totally agree that "custom resolution utility" which supports only standard modes is ... well, I do not want to be insulting...
I have 4k TV which works fine with integrated HD 4600 at 3840x2160x30 resolution using default Microsoft "Standard VGA driver" but I can not make Intel driver to do it. This situation should be really embarrassing for Intel driver programmers.
Répondre
