23806 Discussions
Custom resolution on Iris XE
FabBassi
Good day all, I have a problem of resolution with Iris xe on my mini pc. I need to set a custom resolution of 1920x720. It is really important that I get to set it as it is needed for a very important project . Is there any solution?
MUC
Honored Contributor I
Yes, that should be possible. To better understand your system, please create a System Support Utility Log and attach it here.
FabBassi
Thank you, attached the log hoping it is right.
Best regards
MUC
The monitor is an HP EliteDisplay E232, about 10 years old. It is connected to a GEEKOM IT13 Mini-PC (Core i9-13900HK) via HDMI 2.0 TMDS. The monitor has HDMI 1.4 and informs the graphics driver that it supports a maximum resolution of 1920 x 1080p @ 60 Hz (DMT / CTA-861 standard).
1920 x 720 is unusual and might not work with this monitor. You can use Custom Resolution Utility (CRU) to add resolutions that the monitor doesn't natively support. If you tell me what refresh rate you're aiming for, I can make a suggestion.
