23078 Discussions
Customized resolution for my Dell UltraSharp UP3214Q monitor
I have asked this before but the problem is still there, the latest drivers (4624) don`t support customized resolution for my Dell UltraSharp UP3214Q monitor. I Think the 4424 was the latest that worked, I now I must first install 4424 and make the customized resolution and then install the latest driver
Hello KlasBell,
I understand that latest graphics driver does not allow you to set custom resolution for your Dell* UltraSharp UP3214Q monitor.
Let me apologize for any inconvenience this issue may be causing to you.
In order to help you better I would like to gather more information about the configuration you have in the computer. Please attach to this thread the .xml file the Intel® System Support Utility will generate https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
What is the specific custom resolution you are trying to use?
What type of video cable are you using between the computer and the Dell* monitor?
What is the exact error message you are getting you are trying to set custom resolution?
To attach a file, you must click "Use Advanced Editor" on the upper right hand corner of the response box, then the "attach" option will appear on the bottom right hand corner of the response box.
Fred
1360x768 85hz
DP
something like this translated from swedish. "customized resolutions is not supported by this monitor"
Hello KlasBell,
Thanks for the information you sent to me.
I would like you to try different version of the graphics driver. Please download the following driver https://downloadmirror.intel.com/26229/eng/win64_154028.4501.zip https://downloadmirror.intel.com/26229/eng/win64_154028.4501.zip
As soon as the driver has been downloaded on the keyboard press WinLogo key + r, then type in devmgmt.msc, double click on Display Adapters -> Intel HD Graphics -> Driver tab -> Uninstall -> Select the check box Delete the driver software for this device -> OK, restart the computer, and then reinstall the graphics driver I provided.
You can also install the monitor driver from this link http://www.dell.com/support/home/us/en/19/Drivers/DriversDetails?driverId=JN21K http://www.dell.com/support/home/us/en/19/Drivers/DriversDetails?driverId=JN21K
Does the issue happen only with that specific custom resolution you are trying to set?
Fred
No it did not work, as far as I know it only works with the 4424 drivers
and no you cant custom set any resolution at all, the settings for changing is not available
Hello KlasBell,
I will do more research about this issue. I will post in this thread any information as soon as I have it available.
Fred
Hello KlasBell,
I tried to reproduce the issue in our lab with latest graphics driver, but I was able to create and apply custom resolutions just fine.
In order to help you better I would like to get the Intel Graphics Driver Report. This link will show you how to generate http://www.intel.com/content/www/us/en/support/graphics-drivers/000005848.html http://www.intel.com/content/www/us/en/support/graphics-drivers/000005848.html
Let me also know the exact custom resolution you are trying to set.
Fred
Hello KlasBell,
I was wondering if you still need assistance regarding the custom resolution you are trying to set for your Dell* monitor. If you still need assistance just let me know.
Fred
Did you use a Dell UP3214Q when you reproduce the issue?
Hello KlasBell,
I used a Dell* P2314H monitor. I will try to reproduce the issue with other monitors we have in our lab.
I would like to get the Intel Graphics Driver Report. This link will show you how to generate it https://www.intel.com/content/www/us/en/support/graphics-drivers/000005848.html https://www.intel.com/content/www/us/en/support/graphics-drivers/000005848.html
Fred D.
As you can see my resolution is 1360 x 768 85hz, that is only possible because I customized that with the old 4424 driver, and it stays in memory when I update to a newer driver, but I can`t custom set any NEW resolutions, the settings for changing is gone
Intel(R) HD Graphics 4600
Report Date: Saturday, May 20, 2017
Report Time [hh:mm:ss]: 9:15:26 AM
Driver Version: 20.19.15.4624
Operating System: Windows* 10 Enterprise (10.0.15063)
Default Language: Swedish (Sweden)
Physical Memory: 15296 MB
Vendor ID: 8086
Device ID: 0412
Device Revision: 06
Graphics Output Protocol (GOP) Version: 5.0.1036
Current Resolution: 1360 x 768
Processor: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
Processor Speed: 3998 MHz
Processor Graphics in Use: Intel(R) HD Graphics 4600
Shader Version: 5.0
OpenGL* Version: 4.3
OpenCL* Version: 1.2
* Microsoft DirectX* *
Runtime Version: 12.0
Hardware-Supported Version: 11.1
* Devices connected to the Graphics Accelerator *
Active Displays: 1
Inactive Displays: 1
* Digital Display *
Display Type: Digital
Serial Number: K3R903CN237P
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: DisplayPort
Device Type: DisplayPort
Maximum Image Size
Horizontal Size: 27.56 inches
Vertical Size: 15.35 inches
Supported Modes
640 x 480 (60p Hz)
640 x 480 (75p Hz)
720 x 400 (70p Hz)
800 x 600 (60p Hz)
800 x 600 (75p Hz)
1024 x 768 (60p Hz)
1024 x 768 (75p Hz)
1152 x 864 (75p Hz)
1280 x 800 (60p Hz)
1280 x 1024 (75p Hz)
1280 x 1024 (60p Hz)
1600 x 1200 (60p Hz)
1680 x 1050 (60p Hz)
1920 x 1080 (60p Hz)
1920 x 1200 (60p Hz)
1920 x 2160 (60p Hz)
Power Management Support
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 10 AC 93 40 50 37 33 32
34 17 01 04 B5 46 27 78 3A 73 E0 A3 53 36 B6 26
0D 51 53 A5 4B 00 81 00 B3 00 D1 00 71 4F A9 40
81 80 D1 C0 01 01 4D 6C 80 A0 70 70 3E 80 30 20
3A 00 BA 88 21 00 00 1A 00 00 00 FF 00 4B 33 52
39 30 33 43 4E 32 33 37 50 0A 00 00 00 FC 00 44
45 4C 4C 20 55 50 33 32 31 34 51 0A 00 00 00 FD
00 1D 4B 1F 8C 1E 00 0A 20 20 20 20 20 20 01 B9
70 12 79 00 00 12 00 16 82 10 00 00 7F 07 6F 08
00 00 00 00 00 44 45 4C 93 40 50 37 33 32 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 2A 90
* Digital Television *
Gamma: 2.2
Connector Type: HDMI
Device Type: Digital Television
Maximum Image Size
Horizontal Size: 62.99 inches
Vertical Size: 35.43 inches
Supported Modes
640 x 480 (60p Hz)
720 x 480 (60p Hz)
720 x 480 (60i Hz)
720 x 576 (50p Hz)
720 x 576 (50i Hz)
800 x 600 (60p Hz)
1024 x 768 (60p Hz)
1280 x 720 (60p Hz)
1280 x 720 (50p Hz)
1920 x 1080 (50p Hz)
1920 x 1080 (50i Hz)
1920 x 1080 (60i Hz)
1920 x 1080 (24p Hz)
* Other names and brands are the property of their respective owners.
Hello KlasBell,
Thanks for the additional information you are sharing with us.
I did not find anything unusual in the report you sent.
I am not sure why you are not getting the option to set custom resolutions. Have you by any chance tried different monitor and/or video port?
Fred D.
It works with my 52" sony TV with HDMI connected, and I wouldn't be surprised if I use HDMI to my Dell monitor it would work to, but I have not tried it, whats the point of using HDMI on a 4k monitor when displayport is the only one that support 4k resolution, EDIT I just tried with a HDMI Cable on my Dell 4k monitor and it does work, so it has something to do with displayport
Hello KlasBell,
I would like to gather more details about the issue you are currently having with custom resolutions. Please fill out the form that is in the following link and post it on this forum thread /thread/77761 https://communities.intel.com/thread/77761
Please be as details as possible.
Fred
don`t you have a Dell UP3214Q? or just Another 4k Dell monitor to test would maybe work as well
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
It says "customized resolutions is not supported by this monitor" (In Swedish) when using newer driver, with 4424 driver it works
Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")<p>
Always (100%): X
Often (51-99%):
Sporadic (20-50%):
Very Sporadic (<20%):
Hardware (HW)
Brand and Model of the system.
Asus Sabertooth 1150 Z87 motherboard i7-4790K CPU
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
I only use the built in intel graphic 4600
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)
Dell UltraSharp UP3214Q 4k monitor
How much memory [RAM] in the system (see note2 below).
16GB
Provide any other hardware needed to replicate the issue.
ie: Cables&brand, cable type [vga, hdmi, DP, etc], dock, dongles/adapters, etc
It`s only with displayport the problem occurres, with HDMI it works
Hardware Stepping (see note1 below).
PCI\VEN_8086&DEV_0412&REV_06
XX...
I just discovered that it works (atleast settings for changing is now available) if I change the SETTING IN THE MONITOR from enable to disabled the Displayport 1.2 setting, but then I can only use 29hz or 30hz for most resolutions and that is not acceptable
I also made a video of how it looks when enter the customized resolution window
Hello KlasBell,
Thanks for the additional information you shared with us. After doing additional research in my database I found out that there are other users who have reported that feature works with latest graphics driver.
At this point what I can recommend is checking the following thread for additional suggestions other peers can provide /thread/113612 https://communities.intel.com/thread/113612
Fred D.
Yes but did they have a Dell 4k monitor connected with Displayport and have Displayport 1.2 enabled in the monitors settings? it works with driver 4424 so it should not be so hard to find the problem, it works with the utility CRU but I Think it should work with Intels driver also
Hello KlasBell,
Other users were using different monitors. I just tested another monitor which is a HP* Z27s 27-inch IPS UHD Display, and I was able to create and apply custom resolutions.
At this point there are no other troubleshooting steps I can provide. For more troubleshooting steps you can check the Community thread I provided before.
Another option would be keep using the graphics driver that works for you. Bear in mind that our drivers are generic; we cannot guarantee our generic drivers will work fine on every OEM system.
Fred D.
