23783 Discussions
Cyclical Freezing - graphics problem
mipeic
Hi everyone,
I have a problem with graphics. I own a Lenovo ThinkPad X1 Carbon 2016 - 20FCS0NC02 with a ThinkPad OneLink+ Dock. I got new SAMSUNG monitor S32D850T and plugged it into one of the two DPs. The problem that occurs is that after some time at least a few times a day the monitor freezes cyclically for every 2-3 seconds. It does not stop until I discontent the Dock from the notebook. The notebook is equipped with Intel® HD Graphics 520 and Windows 10 is the OS. I have tried to uninstall/install graphics driver several times and the problem persists.  When I switch the driver to Microsoft Basic Display Adapter this problem does not occur but the picture with Microsoft driver is lags quite a bit.
Interestingly when I connect the monitory directly to my Laptop via HDMI (bypassing the Dock) it has a hard time recognizing monitor's resolution of 2560 x 1440, and only allows 1920 x 1080 nothing higher. Sometimes when I turn the computer on it is the right resolution and other times it is not, without any rule.
Device Details
Adapter Compatibility
Intel Corporation
Video Processor
Intel® HD Graphics Family
Resolution
2560 x 1440
Bits Per Pixel
32
Number of Colors
4294967296
Refresh Rate - Current
59 Hz
Refresh Rate - Maximum
75 Hz
Refresh Rate - Minimum
59 Hz
Provider
Intel Corporation
Version
30.0.100.9684
Date
9/7/2021
Adapter DAC Type
Internal
Adapter RAM
1.00 GB
Availability
Running at full power
Status
This device is working properly.
Location
PCI bus 0, device 2, function 0
David_G_Intel
Hello mipeic
Thank you for posting on the Intel️® communities. Please share more information with us to continue:
  • Intel® System Support Utility (Intel® SSU) results
  • Intel® Graphics Command Center report
    • Open the application
    • "Support" > "System Diagnostic" > "Generate Report
  • Does this happen with other monitors?
  • Does this happen with any specific content or application?
  • Which driver versions did you try?
David G
David_G_Intel
Thank you for the Information provided internally, please remember to reply on this thread to help other community members that might experience the same issue.
As a friendly reminder we only received the SSU results, please share with us the other information left to work with a solution for this case.
David G.
mipeic
I cannot check if the probem happens with other monitors as I do not own other monitor with DP port. What I do know is that it does not happen when I connect the monitor via HDMI to laptop directly or to any other device (appleTV). But one thing is sure, when I switch from Intel(R) HD Graphics 520 30.0.100.9684 (date 9.7.2021.) to Microsoft Basic Display Adapter 10.0.19041.868 (date 21.6.2006.) the problems does not reoccur.
The freezing happens regardless of what program/app I use, web browzer, media app, writing in word.
I tried to use some older version of Intel(R) HD Graphics 520 (don't remember which) but the probem is still there.
mipeic
The ThinkPad OneLink+ Dock only has two DP ports and VGA port (no HDMI) so I cannot try out if the same problem would occour if I bypassed the DP port. I can try it out with VGA port if it makes any sense, will keep you updated. But as I said before, if I pug it into the HDMI port directly on the notebook this cyclical freezing does not occur.
David_G_Intel
Thank you for the information provided. We are investigating this request, the updates will be posted on the thread.
David G.
David_G_Intel
Hello @mipeic
For testing purposes you can try the latest version of our graphics driver 30.0.100.9805:
It's always recommended to use the OEM drivers, their latest version is 27.20.100.9171. If the issue persists even when using the OEM driver, the communication between the dock and the laptop could be the problem. In that case we recommend checking with the manufacturer for support. Docks usually need firmware updates, make sure yours is up to date.
David G
mipeic
I have installed you new graphics driver 30.0.100.9805 but the same problem still happens. Also I have tried to use OEM driver from Lenovo but it cannot be installed as it leaves an error "this operating system is not supported" although I have checked several times my OS (Windows 10 64 bit) should be working.
Thank you,
I will try to contact Lenovo to resolve the problem
