23090 Discussions
D435 camera won't publish infra2 topic
rodolfo76
An update or a wrong setting seems to have stopped infra2 ROS topic from being published. This is to work with rtabmap software. At first the camera worked perfectly with the mapping software, with infra1 and infra2 stereo image streams. Now I can't get camera to produce infra2 at any time. Is this from a software or firmware update? I am using the Nvidia Jetson TX1 board, Ubuntu 18.04, and ROS Melodic.
rodolfo76
Turns out this is simple: the USB cable being used wasn't 3.0 type. Cable as well as jacks must have blue plastic ends inside plug
oanteuhtoaheaoeuoaeu
thanks for posting solution!
DeividA_Intel
Hello rodolfo76,
I am glad to know that you noticed the source of the issue, and tracked it to the compatibility with the USB 3.0. Just a friendly advice, remember to add the Intel product that may be related to the issue (graphics, processor, wireless, etc).
Also, I recommend you to get in contact with the laptop/motherboard manufacturer to get more details of your computer and troubleshooting steps if needed.
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
