22775 Discussions
DCH driver change my monitor 's bit depth from 8 to 6
NinjaUmbra
DCH driver change my monitor 's bit depth from 8 to 6 however traditional OEM driver can bring 6 to 8 bit depth. It also have a problem that the latest dch driver control center tells me dhcp is wrong but my graphic has enable dhcp function and this error only occur in recent dch driver version!
why dch driver reduce bit depth?
AlHill
Since you have a laptop, use BOTH the intel and nvidia graphic drivers as supplied by the laptop manufacturer.
AlHill
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
NinjaUmbra
This is OEM Driver Performance
NinjaUmbra
This is intel dch driver performance, also after this driver the fonts become a little blurred and the screen become more delightful
AlHill
NinjaUmbra
Ok but i think this may be bug because many people meet this problem after install dch driver.
NinjaUmbra
what about HCDP error this does not happen in early dch driver
Sebastian_M_Intel
Hello NinjaUmbra,
Thank you for posting on the Intel® communities.
I can see based on the report you provided that you are using the Windows* 10 Insider Preview Build 21313; for these Operating Systems (OS) builds, the driver most likely comes from Microsoft's side through Windows updates. Also, since you are part of the insider group, any feedback or questions should go directly to Microsoft* as this is their request.
On the other hand, the recommendations provided by the community are correct; you should be using the drivers provided by your OEM. Installing Intel generic drivers will overwrite your OEM customized driver. OEM drivers are handpicked and include customized features and solutions to platform-specific issues.
Sebastian M
Intel Customer Support Technician
