23527 Discussions
DG45FC HDMI Black level ?
I have this board and it is connected to Samsung UE40B7000 via HDMI.
Installed system - Windows 7 Home Premium, 64-bit version
Installed graphic driver - 15.16.5.64.2021
My problem is with black level on TV ... black in movies aren't black but gray ... i asking on some servers and get information about 'color range 16-235' instead of 0-255 in RGB ... someone says that is possible in graphic drivet set which 'range' want to use. But I cannot find it in this driver. Can someone give me a clue to sovle this problem ... it's really ugly watching gray space in STAR WARS instead of black deep space
OK ... i find the way from the other side ... in TV menu is possible to set 'HDMI Black'' and that solve this "gray problem"
ROBERT_U_Intel
put your tv's black level back and install driver version 15.17.1.64.2086 (8.15.10.2086) from 3/4/2010... this will fix the real problem (at least it did for me). driver version 8.15.10.2082 had the black level problem. there was one more release in between these 2 versions, but i did not try that one so i can't say whether it will deepen the black back to where it is supposed to be.
link to the driver: http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3231&DwnldID=18804&lang=eng http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3231&DwnldID=18804&lang=eng
