23854 Discussions
Dedicated video ram
FAlta
Hello, I have a laptop that has a 3 GB ram and intel hd graphics with a dedicated video ram of 64 MB and I want to increase it to 128 MB. I tried to change it via the BIOS but the option is not there. So, is it ok to increase it via the registry? Does this will harm my laptop? I'm afraid to break my laptop or make it unbootable. Thanks.
Hello FRS4002
Thank you for joining the community.
In order to help you better, I would like to gather more information about the configuration you have on the computer. Please attach to this thread the TXT file the Intel® System Support Utility will generate: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Steps to save the report:
  1. Run the utility.
  2. Click on "Scan" to get the scanned system.
  3. Once the scan is complete click on "next".
  4. Use the "save" option, save the report to your desktop.
  5. To attach a file, you must click the "Attach" option on the bottom right-hand corner of the response box.
Leonardo C.
FAlta
Here is the txt file.
Hello FRS4002
Thank you for your response.
Looking into your request I seems that changing the dedicated video memory form 64 MB to 128 MB can be done in BIOS settings of your system, if you need assistance to complete the BIOS configuration I recommend to contact the Toshiba* they can also provide you with information about the temperature changes that this change may produce.
Leonardo C.
FAlta
I checked the bios but there is no dedicated video ram option to change. I have a toshiba laptop. Can I change it from the registry?
Hello FRS4002
Given that you were not able to find the option on BIOS, I recommend you to contact Toshiba* for options on how to change the dedicated video memory.
Leonardo C.
