23828 Discussions
Default VAAPI not working correctly
a_snek
I'm still trying to investigate this but when I try using the default vaapi decoder the video is incomprehensible. But if I use vaapi-copy it seems to work fine and also use "VideoEnhance" on the GPU
System:
ryzen 3600g
32gb ram 2600mhz
intel A750
Hugo_Intel
Hello a_snek
Thank you for posting on the Intel Communities. I am sorry to hear that you are experiencing issues when trying to use vaapi to play videos. Please let us know the following information in order to assist with this issue:
1.-Please make sure to use the latest Graphics driver. You can download them from this link.
2.-Please share with us the steps you used to reproduce this issue.
3.-Share a short video showing this issue.
4.-Please run the Intel® System Support Utility and attach the log file. You can follow these instructions to create the log:
  • Open Applications -> Accessories -> Terminal
  • From the current director, navigate to the current folder where the ssu.sh file resides. For example if you saved the ssu.sh to a folder called "SSU File" the command would be: cd "SSU File"
  • Run the ssu.sh file using this command: ./ssu.sh <parameter=0|1> where 0 = off and 1 = enabled
  • Use the parameter definitions included in the readme to determine which parameter to use.
  • If no parameter is specified and only ./ssu.sh is run, it will capture all system information with the exception of 3rd party logs which must be specified. If no output file is specified, the SSU will write the output to file <sytemname>.txt.
Hugo O.
Hugo_Intel
Hello a_snek
I hope you are doing fine.
Hugo O.
Hugo_Intel
Hello a_snek
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Hugo O.
