- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Hello
I have installed Windows 7 build 7077 on my laptop Dell inspiron
1525 , which worked very perfect so far , however , i can't play
GAMES , i tried several times to update my Graphic Card driver Intel ,
which is updated ( to the last edition ) , though the problems still
exist .
My graphic card is : Video Card Driver Intel GM965 ( which seems ok ) .
I Install Windows 7 build 7100 to stuck at the same problem , i tried
Several games indeed . Starting from Warcraft , even the old
StartCraft , You can add
AssultCube ,
AlienArena ,
Nexuiz ,
OpenArena ,
Unreal T ,
And some MMO games as well as SecondLife and Rakion
I don't know what's really the problem in here , So i tried to install
Windows Vista Graphic Driver in here , and it does not finish
installing as well .
Other than that everything is working perfectly .
Any suggestions ?
Best regards
Lien copié
3 Réponses
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
HEY IM PLANING TO BUY THE SAME UNIT I HOPE THAT THE GAMES LIKE ASSASINS CREED WILL RUN ON IT
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
How about "What's failing?"
"i can't play GAMES" seems to be a statement of operator skills rather than a discription of a problem.
Any error messages, Direct x loaded, are the games compatable with win7 ?
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Your not going to play to many grapgic intense games with the intel 965 chipset.It just doesnt have the power to push what is needed in alot of newer games.And forget assins creed,it runs slow on my Acer aspirewith gma hd igp.
Répondre
Options du sujet
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
