23525 Discussions
Difficulty playing UHD 4k (3840×2160) video.
DUrza
Thanks for your time and attention,
I'm having mixed results playing 4k (3840 × 2160) video. Though mp4 seems to be okay, HEVC x.265 mkv is giving mixed results (none good).
The video seems to play best using the native Windows video player. The audio seems fine, but the video stutters significantly.
Any advice or suggestions?
Thanks again,
Dugen
Operating System: Microsoft Windows 10 Home(10.0.16299 Build 16299)
Physical Memory (Installed): 8 GB
Processor: Intel(R) Core(TM) i7-6500U CPU @ 2.50GHz
System Type: x64-based PC
Total Installed Updates: 16 Updates - See Detailed View for more information
Display Adapter(s): Intel(R) HD Graphics 520 22.20.16.4771
System Manufacturer: Dell Inc.
System Model: 0GN5VG
Network Adapter(s): Intel(R) Dual Band Wireless-AC 3165 19.51.8.2
Disk(s): SanDisk Z400s 2.5 7MM 256GB 130.10 GB (available) 10.0.16299.15
Adapter Compatibility Intel Corporation
Adapter DAC Type Internal
Adapter RAM 1.00 GB
Availability Running or Full Power
Bits Per Pixel 32
Caption Intel(R) HD Graphics 520 http://www.intel.com/content/www/us/en/search.html?keyword=HD+Graphics+520
CoInstallers oem17.inf,iSKLD_w10_DS,Internal,Intel(R) HD Graphics Family
Color Table Entries 4294967296
Dedicated Video Memory Not Available
Driver igdkmd64.sys
Driver Date 08/12/2017 05:00 PM
Driver Path C:\WINDOWS\system32\DriverStore\FileRepository\igdlh64.inf_amd64_453d2af85bf95078\igdkmd64.sys
Driver Provider Intel Corporation
Driver Version 22.20.16.4771
INF oem17.inf
INF Section iSKLD_w10_DS
Install Date Not Available
Installed Drivers C:\WINDOWS\System32\DriverStore\FileRepository\igdlh64.inf_amd64_453d2af85bf95078\igdumdim64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\igdlh64.inf_amd64_453d2af85bf95078\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\igdlh64.inf_amd64_453d2af85bf95078\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\igdlh64.inf_amd64_453d2af85bf95078\igd12umd64.dll
Last Error Code Not Available
Last Error Code Description Not Available
Last Reset Not Available
Location PCI bus 0, device 2, function 0
Manufacturer Intel Corporation
Microsoft DirectX* Version 11.X
Monochrome No
Number of Colors 4294967296
Number of Video Pages Not Available
PNP Device ID PCI\VEN_8086&DEV_1916&SUBSYS_06FF1028&REV_07\3&11583659&0&10
Power Management Capabilities Not Available
Power Management Supported Not Available
Refresh Rate - Current 60 Hz
Refresh Rate - Maximum 60 Hz
Refresh Rate - Minimum 48 Hz
Resolution 3840 X 2160
Scan Mode Noninterlaced
Service Name igfx
Status OK
Video Architecture VGA
Video Memory Unknown
Video Processor Intel(R) HD Graphics Family
BIOS 1.17.0, DELL - 1072009
Caption Motherboard
Chipset Intel(R) 100 Series http://www.intel.com/content/www/us/en/search.html?keyword=100+Series
Date 06/19/2017 05:00 PM
Manufacturer Dell Inc.
Model Not Available
Part Number Not Available
PNP Device ID Not Available
Product 0GN5VG
Serial Number /41GDB82/CN7620662N0211/
Status OK
Version A00
KB2468871 Microsoft .NET Framework 4 Client Profile [Not Available]
KB2468871 Microsoft .NET Framework 4 Extended [Not Available]
KB2468871v2 Microsoft .NET Framework 4 Client Profile [Not Available]
KB2468871v2 Microsoft .NET Framework 4 Extended [Not Available]
KB2478063 Microsoft .NET Framework 4 Extended [Not Available]
KB2478063 Microsoft .NET Framework 4 Client Profile [Not Available]
KB2533523 Microsoft .NET Framework 4 Extended [Not Available]
KB2533523 Microsoft .NET Framework 4 Client Profile [Not Available]
KB2544514 Microsoft .NET Framework 4 Extended [Not Available]
KB2544514 Microsoft .NET Framework 4 Client Profile [Not Available]
KB2600211 Microsoft .NET Framework 4 Client Profile [Not Available]
KB2600211 Microsoft .NET Framework 4 Extended [Not Available]
KB2600217 Microsoft .NET Framework 4 Client Profile [Not Available]
KB2600217 Microsoft .NET Framework 4 Extended [Not Available]
KB4048951 Security Update [11/26/2017]
KB4048955 Security Update [11/23/2017]
Architecture x64
ATPO Not Available
Caption Intel64 Family 6 Model 78 Stepping 3
Chipset Name Intel(R) Core(TM) i7-6500U CPU @ 2.50GHz http://www.intel.com/content/www/us/en/search.html?keyword=Core+i7+6500U+CPU+
CPU Speed 1.10 GHz
Current Voltage 1.7 volts
Driver Not Available
Driver Date 04/21/2009 12:00 AM
Driver Path C:\WINDOWS\system32\drivers\intelppm.sys
Driver Provider Microsoft
Driver Version 10.0.16299.15
Ext. Family Not Available
Family Intel Core™ i7-2760QM
FPO Not Available
INF cpu.inf
INF Section IntelPPM_Inst.NT
Level 1 Cache 2 x 64 KB
Level 2 Cache 2 x 512 KB
Level 3 Cache 4 MB
Load 14%
Manufacturer GenuineIntel
Model 78
Number of Cores 2
Number of Cores Enabled 2
Number of Logical Processors 4
Part Number To Be Filled By O.E.M.
Processor ID BFEBFBFF000406E3
Revision 19971
Serial Number To Be Filled By O.E.M.
Service Name intelppm
Status OK
Stepping 3
Version Not Available
BaseBoard Manufacturer Dell Inc.
BIOS Mode UEF...
Dugen: You are welcome. Thank you very much for letting us know those updates.
You can always use the following tool to send the video:
https://uploadfiles.io/ https://uploadfiles.io/
The content on the above site is not controlled by Intel. This information is offered for your convenience and should not be viewed as an endorsement by Intel for the merchants or services offered there
Alberto R
DUrza
Here is a random video clip that I downloaded from YouTube. It was saved as a 4k .mkv file.
https://ufile.io/rarbt https://ufile.io/rarbt
With Windows Media Player - Only Video, No audio, and the video is choppy (a consistent maybe 3 stops per second).
With VLC - Only audio, no video. Occasionally tries to render something, but it just comes out at large light gray squares.
This is consistent across numerous video clips. This being only just one of them.
Thanks so much,
Dugen
Dugen: Thank you very much for providing the video. We will do further research on this matter, as soon as I get any updates I will post all the details on this thread.
Alberto R
Dugen: I just received an update on this matter, actually this problem seems to be the same issue as reported here: https://communities.intel.com/thread/116723 https://communities.intel.com/thread/116723
We are already aware of this situation and it has already been escalated internally, please keep checking the thread above for updates in regard to a possible solution.
Alberto R
Ede_J1
On my pc i have difficulties playing uhd videos too.
Dell precisiontower 3620, intel hd graphics 630 (C236 chipset with 7700k):
Movies & TV, media player, vlc player: cannot play video
Custom pc with asus prime B250M-K, intel hd graphics 630 (B250 chipset with 7700):
Movies & TV, media player, vlc player: video plays ok
Now I tried media player classic (https://mpc-hc.org/ https://mpc-hc.org/) and surprisingly the video plays ok,
with a cpu load of 3% and a gpu load of 55%.
Perhaps you could try this player too, and if it works, what is different to the Movies & TV application?
