23099 Discussions
Disk upgrade - RAID 0 to RAID 10
Hey there. Today I bought new hard disks because I needed more space for of my photography.
I bought 4 disks and I want to put them in RAID 10 (or RAID 1+0). I still have my current disks in RAID 0. What I want to do is get the data from the RAID 0 disks, and put that on the new RAID 10 disks. So in total I have 6 disks now - 2 disks in RAID 0 (with everything on it) and 4 new 'empty' disks that should be in RAID 10, with the data from the RAID 0 disks.
I have 6 sata-ports, so I should be able to hook all the disks up at once if needed (can't use my DVD-rom then tho).
Now the big question is - How do I get the data from the RAID 0 disks to the 4 new disks without loosing the RAID-settings? Is there a way to transfer the data to the disks? I really don't want to format and start all over...
Here's what I have tried so far:
- plugging 2 of the new disks and upgrading the 2 old + 2 new disks to a new RAID 10. Failed because my RAID drives doesn't have an option to ugrade from RAID 0 to RAID 10.
- plugging in the 4 new disks, putting them in RAID 10 and then using a Windows complete PC back-up. Failed because Windows gets confused with the new drives (size doesn't match).
My RAID driver is from my mainboard, it's Intel Matix Storage manager v 8.7.0.1007 ich9r wRAID5 (no clue if that info is useful :P)
Thanks for the help!
System configuration:
Processor : Intel Core 2 Quad Q9400 @ 2666 MHz
8.0 gig RAM DDR2
2x Samsung 500 GB Sata2, RAID 0
ATI Radeon HD 5600 Series
Monitor Type : Idek Iiyama PLE2407HDSD - 24 inches
MSI 975X Platinum Motherboard
Creative 7.1 X-fi Fatal1ty FPS Audio card
Pinnacle PCTV 110i capture Device
750Watt PS
I have looked from MSI and review sites for this board and it only has 5 SATA ports and only 4 of them are Intel and even if you some how got a board with 6 SATA still only 4 of them are Intel as that's the max the ICH7R want up to.
You will have to reformat and start over I don't know what new disks you have but you can only make a array upto 2TB with the ICH7R so 4 1TB drives in RAID 10 will be 2TB.
Hi Peter, thank you for your fast reply. It seems things don't look too good then because I bought 4 drives, each 2TB each. Data loss and not beeing able to use the maximum ammount of diskspace seems like a bad deal to me. I'll figure something out. Thank you for your input
