23818 Discussions
Display Driver Has Stopped Working and Recovered Successfully.
JMcLa5
I'm having a problem with a coworker's laptop where she gets a message saying that:
Display Driver Has Stopped Responding and Recovered. Display Driver Intel HD Graphics Drivers for Window stopped responding and has successfully recovered.
It's been having ever since she got the computer last month. It will happen randomly or when she tries to play a video in a media player. I've updated the BIOS and reinstalled the driver from the manufacturer. I also tried to installed the driver from Intel but I get a message saying that the computer "does not met the minimum requirements".
Below is the dxdiag report. Could someone try to help me out? Thanks.
System Information
Time of this report: 4/21/2014, 17:33:07
Machine name: MEGAN-PC
Operating System: Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130828-1532)
Language: English (Regional Setting: English)
System Manufacturer: TOSHIBA
System Model: PORTEGE R30-A
BIOS: Default System BIOS
Processor: Intel(R) Core(TM) i7-4600M CPU @ 2.90GHz (4 CPUs), ~2.9GHz
Memory: 8192MB RAM
Available OS Memory: 8102MB RAM
Page File: 2504MB used, 13695MB available
Windows Dir: C:\windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
<p style="margin-top: auto; margin...
Kevin_M_Intel
Hi jmclaughlin6569,
I am sorry you are having problems installing the driver but let me help you.
Based on your description I recommend you installing the latest driver from our side that can be found at the following link:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3720&DwnldID=23714 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3720&DwnldID=23714
Please check the following link also that contains important information I how to solve this problem:
/docs/DOC-22542 https://communities.intel.com/docs/DOC-22542
Hope it helps!
vyada5
display driver stooped and recovered successfully problem....here's my dxdiag file....
System Information
Time of this report: 6/11/2014, 00:10:56
Machine name: VIP-PC
Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7600) (7600.win7_rtm.090713-1255)
System Manufacturer: HCL Infosystems Limited
System Model: HCL Notebook
Processor: Intel(R) Core(TM)2 Duo CPU T5800 @ 2.00GHz (2 CPUs), ~2.0GHz
Memory: 4096MB RAM
Available OS Memory: 3004MB RAM
Page File: 1193MB used, 4811MB available
Windows Dir: C:\Windows
DxDiag Version: 6.01.7600.16385 32bit Unicode
DxDiag Previously: Crashed in system information (stage 4). Re-running DxDiag with "dontskip" command line parameter or choosing not to bypass information gathering when prompted might result in DxDiag successfully obtaining this information
DxDiag Notes
Display Devices
Card name: Mobile Intel(R) 45 Express Chipset Family (Microsoft Corporation - WDDM 1.1)
Manufacturer: Intel Corporation
Chip type: Mobile Intel(R) 4 Series Express Chipset Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2A42&SUBSYS_0772152D&REV_07
Display Memory: 1309 MB
Dedicated Memory: 64 MB
Shared Memory: 1245 MB
Current Mode: 1280 x 800 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: CPT1785
Native Mode: 1280 x 800(p) (60.002Hz)
Output Type: Internal
Driver Name: igdumd32.dll,igd10umd32.dll
Driver File Version: 8.15.0010.1749 (English)
Driver Version: 8.15.10.1749
DDI Version: 10
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 7/14/2009 06:45:31, 3805184 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-6902-11CF-4870-7827A7C2C535}
Vendor ID: 0x8086
Device ID: 0x2A42
SubSys ID: 0x0772152D
Revision ID: 0x0007
Driver Strong Name: igdlh.inf:Intel.Mfg.NTx86...1:iCNT0:8.15.10.1749:pci\ven_8086&dev_2a42
Rank Of Driver: 00EC2001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_B ModeWMV9_C ModeVC1_B ModeVC1_C
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_Al...
Kevin_M_Intel
Please try installing the driver that can be downloaded at the following link:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22165 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22165
In case of having problems during the installation, try the steps at this link:
DMarc9
Hi, same problem since 1 month ago, driver is updated. Here is my DXDIAG txt..
Happens when watching netflix or playing music with Windows Media Player...
System Information
Time of this report: 8/6/2014, 19:24:44
Machine name: M*********-LT
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.140303-2144)
Language: Spanish (Regional Setting: Spanish)
System Model: Satellite A305
BIOS: InsydeH2O Version 2.20
Processor: Pentium(R) Dual-Core CPU T4200 @ 2.00GHz (2 CPUs), ~2.0GHz
Memory: 4096MB RAM
Available OS Memory: 3964MB RAM
Page File: 2860MB used, 5065MB available
DxDiag Notes
Display Devices
Card name: Mobile Intel(R) 4 Series Express Chipset Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2A42&SUBSYS_FF1E1179&REV_07
Display Memory: 1759 MB
Dedicated Memory: 128 MB
Shared Memory: 1631 MB
Monitor Id: SEC3741
Native Mode: 1280 x 800(p) (60.004Hz)
Driver Name: igdumd64.dll,igd10umd64.dll,igdumdx32,igd10umd32
Driver File Version: 8.15.0010.2869 (English)
Driver Version: 8.15.10.2869
DDI Version: 10
Driver Date/Size: 11/14/2012 16:57:06, 6549504 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-6902-11CF-FC79-14DFA7C2C535}
Vendor ID: 0x8086
Device ID: 0x2A42
SubSys ID: 0xFF1E1179
Revision ID: 0x0007
Driver Strong Name: oem63.inf:IntelGfx.NTamd64.6.0:iCNT0:8.15.10.2869:pci\ven_8086&dev_2a42
Rank Of Driver: 00E62001
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-...
Kevin_M_Intel
Hi vips,
I am sorry for the delay.
Thanks for all the information you have provided. Please uninstall the current driver you have installed and download and install the driver at this link:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=22165 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=22165
If you find problems during the installation, try the steps mentioned here:
Kevin m
DMarc9
My Toshiba Notebook is 64 Bits, this driver https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=22165 Intel® Download Center is for 32 bits architecture...
Which Driver should I download ?
Dario
LAlve3
I also have this problem.
It started nearly a month ago in my laptop (Asus N75SF with a intel HD3000 and Nvidia GT555m).
This issue manifested in Flash Games on an browser (internet explorer, firefox, chrome).
I didn´t solve this issue, but, when working on battery power, the graphics problem didn´t appear. Only on AC Power. This fact was very strange for me.
So I went to the power saving definitions and change the (graphics and internet explorer, usb, etc.) settings when working on AC power to match the settings when working on battery power. This means I have to lower the specs of my laptop in order to work with it.
This procedure should not be the sollution for this kind of problem.
But it was the only way I find to fix this issue.
All my drivers are updated to the latest oficial drivers available.
I hope there will be a solution for this as soon as possible.
Sorry for the English.
