23782 Discussions
Display Scaling API for Intel Graphics
Nitesh1
Can we programmatically change the display scaling with any of the Intel API's or Microsoft API's.
I would like to do Centered scaling through code instead of using Intel Command Center to do so.
I found this content, does it work with Intel driver
https://docs.microsoft.com/en-us/windows-hardware/drivers/display/scaling-the-desktop-image
JosueO_Intel
Hello Nitesh1,
Thank you for posting on the Intel®️ communities.
I will proceed to check your inquiries internally and post back soon with more details.
Josue O.
JosueO_Intel
Hello Nitesh1,
Please share with us the following information:
  1. What is the hardware? Is it laptops or desktops?
  2. Will be this on native resolutions or are you looking to change for other resolutions higher/lower?
  3. What is the goal with this change via coding? Will it be applied to a lot of computers at the same time?
  4. Is this on built-in or external monitors if so how are they connected in case it is?
Josue O.
Nitesh1
1. It is desktop
2. Not for native resolution. I will lower the resolution and change display scaling
3. Yes it will be applied on to multiple desktops. We don't want end user to do. We will automate with programmatically
4. For external monitors. They are connected via DVI/HDMI/DisplayPort
JosueO_Intel
Hello Nitesh1,
Thank you for the information provided, please let us know the model of integrated GPU you will be using to try to perform this process.
Josue O.
Nitesh1
JosueO_Intel
Hello Nitesh1,
Thank you for the information provided, we will continue to check the issue internally and post back soon.
Josue O.
