22936 Discussions
Display driver stopped responding and has recovered Error with Iris 5100
LLee30
Is there anything i can do other than wait for an new driver to be released? Is there a beta driver that I can try to see if it fixes the problem?
I just found a slightly newer driver
64bit - win64_15407.4279.exe
but the problem remains exactly the same as before 3 restarts of the driver and then the driver is locked out
The take from other support websites puts the blame squarely on the Iris driver so I asked once more are Beta version that fix this problem available to test yet?
I am happy to test and I have a separate hard drive with a bog standard clean install of windows 10 64 that I can use for tests. This is an Apple MacMini 7,1 Computer To the highest spec currently offered by Apple
Hardware Overview:
Model Name: Mac mini
Model Identifier: Macmini7,1
Processor Name: Intel Core i7
Processor Speed: 3 GHz
Number of Processors: 1
Total Number of Cores: 2
L2 Cache (per Core): 256 KB
L3 Cache: 4 MB
Memory: 16 GB
Boot ROM Version: MM71.0220.B03
SMC Version (system): 2.24f32
Intel Iris:
Chipset Model: Intel Iris
Type: GPU
Bus: Built-In
VRAM (Dynamic, Max): 1536 MB
Vendor: Intel (0x8086)
Device ID: 0x0a2e
Revision ID: 0x0009
Displays:
LED Cinema Display:
Display Type: LCD
Resolution: 1920 x 1200
Pixel Depth: 32-Bit Color (ARGB8888)
Display Serial Number: 2A92311M0K0
Main Display: Yes
Mirror: Off
Online: Yes
Rotation: Supported
Connection Type: DisplayPort
I am a retired IT pro that knows how to do Proper QA testing and I cm provide detailed reports and logs...
I am here and willing to help for no cost to Intel
Display driver Intel HD Graphics Drivers
for Windows 8(R) stopped responding
and has successfully recovered
The above Msg is seen three times and it looks like this
this warning popup( with the Yellow X in a circle at the left top of the pop up) in the lower right corner blanks and reappears Three times and is replaced by another popup of the same sort ...
Allan_J_Intel1
Apple has requested that all questions regarding Apple systems and software be addressed directly with Apple support. I recommend checking the link below for troubleshooting assistance on your Apple computer:
http://www.apple.com/support/macmini/ Mac mini - Apple Support
Allan.
LLee30
The problem was caused by microsoft and the way it uploaded and updated the win 8.1 installed and working to Windows 10-64 .
they replaced the iris graphics driver provided by the bootcamp installation thumb ( that you create to get it all working) which was
3345 with one in the 4000 series... And any attempt to fix the problem in Windows points you to the intell web site wher that driver
gets updated to the current driver (in this case iris 4279) the fix such as it is requires that a fresh copy of 3345 be obtained by making
a new thumb drive and running the setup in the second of the the two intell marked folders in it to cause the needed reversion.
this is still not a prefect solution but it does allow many programs to run that were puting up the errors delineated in the first post in this
tthread.... It is clear that apple needs to update the files in the thumb drive that they have the user create with bootcamp assistant to reflect
wwhat is needed by Windows 10. I expect when they get today's release of OS X 11.11.x sorted and rinning smoothly that they will return
their attention to the needed changes to Bootcamp for Windows 10
I hope this thread will help any others looking for a way around this problem
cheers
Cesar_B_Intel
Hello Windshadow
Thank you for sharing your findings to the Intel® Communities, we appreciate your time and hope this will help others with the same issue.
Caesar B.
