23752 Discussions
DisplayPort++ supported in QM57 Express Chipset ?
If a oem produces a system board using the QM57 Express PCH chip, and includes a DisplayPort connector, will the connector be DisplayPort++ compatible ? The chip seems to provide dual mode operation of the display port pins, ie HDMI/DVI and DisplayPort so it should be capable of this ?
Haach
Ich benötige Windows XP 32-bit Treiber für das Notebook, PANASONIC TOUGHBOOK CF-52 MK3.
Lt. HWINFO sind folgende Hardware-Komponenten verbaut:
Prozessor Intel Core i5-520M, 2,4 GHz
Hauptplatine Intel QM57
Video: Intel HD Graphics, Ironlake, Video-BIOS-Version: 1948 PC 14.34 25.11.20..., Treiber-Informationen PCI\VEN_8086&DEV_0046...
Audio: Audioadapter Intel 5 Series/34x0 Chipsatz PCH-High Definition Audio Cont...,
AlHill
Sorry, that was 15 years ago.
And, you should install the chipset software provided to you by Panasonic (if it still exists).
Also, this thread is 15-years old.  You really should have started a  new thread for yourself.
[W10 is this generation's XP]
