22961 Discussions
DisplayPort to HDMI doesn't work on Core i5 2520m
I have a Lenovo x220 with a core i5 2520m processor and integrated Intel HD Graphics (can't seem to find a model number for the graphics chipset). I bought a DisplayPort to HDMI connector and have tried it with both my TV (Sony Bravia) and my monitor (Viewsonic VX2260wm) and I get different - but both broken - results.
With the TV the output isn't even recognised as connected. The only time it has ever worked is when updating the Intel HD graphics drivers on Windows 7 Professional (64-bit). I first noticed it when I updated the graphics and it worked upon reboot. I thought that had fixed it, but another reboot and it stopped working - no matter how many times I rebooted or tried to "detect" the display. If I uninstall the Intel drivers and re-install them I get the same result. It works once and never again. I find this part really odd, but cannot figure out what might cause it.
With the Viewsonic monitor I am also using the DisplayPort to HDMI adapter and this time it works... but the dimensions are not detected properly. So the monitor is detected and is supposedly use 1366x768, but the sides of the screen are cut off. It seems Windows thinks the monitor is wider than it is. I have the exact same behaviour in Ubuntu (11.04 and 11.10). Again, odd and I cannot figure out what might cause it. Interestingly if I change the resolution (in Windows or Ubuntu) to be lower (1080x900, I think) it works. Though it is somewhat stretched because the resolution is 16:10 rather than 16:9.
I have done a bunch of investigation and I noticed an article on Wikipedia about DisplayPort compatibility with HDMI [1]. In that article is says:
"DisplayPort is capable of directly emitting single-link http://en.wikipedia.org/wiki/HDMI HDMI and http://en.wikipedia.org/wiki/Digital_Visual_Interface DVI signals using Dual-mode DisplayPort...Dual-mode DisplayPort chipset detects the DVI or HDMI passive adapter and switches to DVI/HDMI mode...Dual-mode compatible ports are marked with the DP++ logo; most current DisplayPort graphics cards and monitors support this mode."
Could there be a problem with detecting that link? Is it not switching modes properly? This is the only thing I can figure out. There is a DP++ logo on the DisplayPort, so it must support this mode. Does anyone know of any such issues? I'm a bit desperate at this point. 😕
[1] http://en.wikipedia.org/wiki/DisplayPort# Compatibility_with_HDMI.2FDVI http://en.wikipedia.org/wiki/DisplayPort# Compatibility_with_HDMI.2FDVI
The usage of video cable adapters is not supported with an Intel graphics controller, this could be the reason of your issue.
I recommend using straight video cables, such HDMI to HDMI or Display port to Display port and check if there is any customized driver available for your computer model.
Dago.
Thanks for the answer, but I'm still a bit confused. The port on my laptop has a DP++ logo on it - as I pointed out in my original post. The DP++ logo is for DisplayPort interfaces capable of directly emitting single-link http://en.wikipedia.org/wiki/HDMI HDMI and http://en.wikipedia.org/wiki/Digital_Visual_Interface DVI signals using Dual-mode DisplayPort through a passive adapter. Therefore, to say the chipset doesn't support using an adapter of any type seems patently incorrect.
Thanks again for the answer. Any other ideas?
