22824 Discussions
Does Intel ARC Pro A40 bulk package to provide the full high bracket?
JasperC
Hi Intel supporter
Does Intel ARC Pro A40 bulk package provide the full high bracket?
If not, how can we get it? Thanks!
Jasper C.
Jean_Intel
Hello JasperC,
Since we have not received a response, we will proceed to close this thread. As we mentioned, the Intel® Arc™ Pro A40 comes with a low-profile bracket only. If you require additional information, please open a new question, as this thread will no longer be monitored by Intel.
Best regards
Jean O.
Jean_Intel
Hello JasperC,
Thank you for posting in the Intel Communities, we see that you are looking for information about the Intel ARC Pro A40, and you would like to know if the card package can provide the full high bracket. We would be more than happy to help you, but first, we want to confirm if we fully understand your question. Are you looking for a bracket to use in a normal case instead of using it in a low profile? We also would like to know the use case you plan for this GPU.
Best regards
Jean O.
JasperC
Hi Jean O.
Thanks for your responses, Yes! My case supports the full-high bracket and the Intel Pro A40 bulk package has the low-profile bracket only.
Best Regards
Jasper C.
Jean_Intel
Hello JasperC,
Thank you for the information provided, in order to properly answer your query, we will proceed to look into this matter internally. We will post back as soon as we have more details.
Best regards
Jean O.
JasperC
Hi Jean O.
Thanks and waiting for your update.
Jasper C.
Jean_Intel
Hello JasperC,
We would like to let you know that the Intel® Arc™ Pro A40 comes with a low-profile bracket only, and the Intel® Arc™ Pro A50 is the one that comes with a full high bracket.
Best regards
Jean O.
Jean_Intel
Hello JasperC,
We are checking in your thread to confirm if you have any other questions regarding the Intel® Arc™ Pro A40. Let us know if you require further assistance.
Best regards
Jean O.
Jean_Intel
Hello JasperC,
Best regards
Jean O.
