23272 Discussions
Does Intel HD 630 support 240 Hz or 144 Hz?
ggabo1
Does Intel HD 630 integrated graphics support 240 Hz or 144 Hz refresh rate on 1080p resolution?
AlHill
Provide your processor model number.
Doc
n_scott_pearson
Based upon the DisplayPort (DP) 1.2 standard, 144Hz should be possible. 240Hz slightly exceeds the bandwidth limit and may or may not work.
ggabo1
The processor is G4600 and the motherboard only has HDMI, DVI and D-Sub.
n_scott_pearson
Well, that changes things...
  • For VGA (D-Sub), you will be limited to 60Hz.
  • For Single-Link DVI, you will be limited to 60Hz.
  • For Dual-Link DVI (if supported), you will be limited to 120Hz.
  • For HDMI 1.4, you will be limited as follows: 720p: 120Hz, 1080p: 144Hz (240Hz maybe), 1440p: 75Hz (144Hz maybe), 2160p: 30Hz (75Hz maybe).
  • For HDMI 2.0 (if supported - but doubtful), you will be limited as follows: 720p: 120Hz, 1080p: 240Hz, 1440p: 144Hz (240Hz maybe), 2160p: 60Hz (120Hz maybe).
If nothing else, it was educational digging out this information,
ggabo1
Oh, wow! Thank you very much!
