23526 Discussions
Does Intel® HD Graphics 630 support 3840x2160@60Hz for multiple displays?
JZimm3
Hello!
I would like to know: does the Intel HD Graphics 630 (like the one the Pentium G4600 has) support UHD@60Hz for two displays?
According to Intel ARK the max resolution for DisplayPort is 4096x2304@60Hz, so one display at 3840x2160@60Hz is supported. But what if I have a motherboard that has two DP connectors (like https://www.msi.com/Motherboard/B150M-PRO-DDP/Specification Specification for B150M PRO-DDP | MSI Global ), can I run a 3840x2160@60Hz monitor at each of these connectors? In case it matters, operating systems are both most recent Windows and Linux versions.
Thanks in advance!
Hello JensZimmermann,
Thank you for reaching the Intel Communities. I understand you would like to check if the system can handle two displays with the resolution 3840x2160 @60Hz
We can certainly check on that to provide the information required.
This configuration can be achieved while using RAM at the following speed: 18660or 2133
Please check the image attached from datasheet (page 43)
https://www.intel.com/content/www/us/en/processors/core/7th-gen-core-family-desktop-s-processor-lines-datasheet-vol-1.html Datasheet, Vol. 1: 7th Gen Intel® Processor Family for S Platforms
If further questions are present, feel free to let us know.
Esteban C
Esteban C
