23501 Discussions
Second Monitor
AViei3
So my second monitor WAS working, and then starting this week it wasn't. When I plug in the HDMI cable into my laptop, the second monitor lights up (so something is registering) but my computer won't 'detect' the second monitor. I have noticed while I was trying to roll back my Intel driver, that it said my driver edition is from 3/6/2017. However, when I go on Intel's website to have it scan my computer for updates, it says that I have the most up-to-date driver from 10/10/2017. I don't know why that's inconsistent.
I am using Intel HD graphics 520.
Windows is completely updated.
Lenovo is completely updated.
I have rolled back both windows and lenovo updates, neither worked. I've completely reset my laptop (due to other computer issues, not virus related). I've tried all the unplug-replug combos, restarting my computer, waiting, using a different HDMI, none of it works. I'm hoping that this date inconsistency with Intel updates will lead my down the right path to fixing this.
Stefan3D
Here is a list of drivers you can try: https://downloadcenter.intel.com/product/88355/Intel-HD-Graphics-520 Downloads for Intel® HD Graphics 520
None of them has a date stamp 3/6/2017. Did you get the working driver from Lenovo?
Hello av9595,
Thank you for reaching the Intel Communities.
I understand you would like to get that second monitor working again with the system, and we can check this matter for sure by looking for a possible fix or source of the problem.
Some questions I would like to ask:
  • Are you using adapters? or is it a HDMI to HDMI connection?
  • Have you tested the monitor on another computer?
  • Have you tested other monitors or a TV with the computer?
  • Please attach the Intel(R) SSU report to your answer (check below)
  • Were you able to test the drivers provided above? (check below for further instructions)
How to get the SSU report?
If you got errors while trying to install the drivers provided before, please follow these steps to install them:
To be done with .zip version of the driver.
1. Extract the .zip file downloaded
2. Access the device manager and look for display adapters (double-click on it, you should be able to see an Intel(R) HD Graphics adapter or Microsoft Basic Display Adapter")
3. Right-click and select update driver for Intel HD Graphics
4. Select "Browse my computer for driver software"
5. Select "Let me pick from a list of device drivers on my computer"
6. Click on "Have Disk" and find the extracted folder of the driver downloaded
7. Go to "Graphics" folder within driver folder and select the **igdlh64.inf** file and hit open then ok
8. Select Intel HD Graphics XXX under "model" and hit next
Please advise how it goes.
Esteban C
AViei3
Alright to start with, I took some pictures because I'm not the best at explaining things. I have done nothing since my last post, but now my intel device says it's from 2006...
If you look at the first three pictures (they are labeled 3, 4, and 5 because this is not the first post I've made) you'll see that the driver is no saying its from 2006, but when I try and update it, it says that this is the most recent version.
I've tried downloading the most recent myself, but each version I try says that it is not compatible with my computer (even when it is). I have a lenovo yoga 15 with an intel core i7.
I ran the SSU and the review I posted is on image 6 and 7. I also ran the intel updater on the webpage (the one that automatically searches for updates) and it says my computer is up to date.
Stefan3D
Regarding date stamp check out
https://blogs.msdn.microsoft.com/oldnewthing/20170208-00/?p=95395 Why are all Windows drivers dated June 21, 2006? Don't you ever update drivers? – The Old New Thing
Thank you for the answer provided, av9595
Please download this driver: http://intel.ly/2z2RYw7 http://intel.ly/2z2RYw7
Then follow these steps to get it installed:
These steps have been replicated in this video as well: https://www.youtube.com/watch?v=S1KzoQDjMMY https://www.youtube.com/watch?v=S1KzoQDjMMY
If the driver is not getting installed after following those steps, please contact us by chat to get it installed with you live.
Business Hours:
Monday - Friday
7:00 AM to 5:00 PM (Pacific Time)
To start a chat: http://intelsupportchat.force.com/icslivechat/ics_tech_graphics_ww_english_Chat http://intelsupportchat.force.com/icslivechat/ics_tech_graphics_ww_english_Chat
Esteban C
Hello av9595,
This is to do a follow up on your case and find out if you were able to proceed with the steps above and if you have further questions.
Esteban C
