23784 Discussions
Does Intel UHD 620 Graphics processor support HEVC decoding?
SRiab
Dear Intel GPU community
i have  Intel UHD 620 Graphics processor and according to the specification this type of GPU does support HEVC decoding.
However, a list of supported decoders supplied by DXVA2 utility GetDecoderDeviceGuids does not contain HEVC decoder GUID (5b11d51b😞
GUID ee27417f - mpeg2 decoder
 GUID bf22ad00  - mpeg2 decoder
 GUID e07ec519  VC-1 variable-length decoder 2 (not mentioned in dxva2api.h file )
 GUID bcc5db6d   VC-1 variable-length decoder (not mentioned in dxva2api.h file )
 GUID 1b81bea4 - vc1 decoder
 GUID 1b81be68  - h264 decoder
 GUID d79be8da - H264_VLD_Stereo_Progressive_NoFGT
 GUID f9aaccbb  - h264 stereo
 GUID 705b9d82 - h264 multiview
 GUID 91cd2d6e unknown
 GUID 90b899ea  unknown
 GUID 442b942a unknown
 GUID 8c56eb1e  unknown
 GUID 75fc75f7    unknown
 GUID 463707f8   vp9
 GUID a4c749ef    unknown
 GUID 76988a52  unknown
 GUID 80a3a7bd  unknown
 GUID a74ccae2    unknown
 GUID 1b81be94 - WMV-9 decoder
 GUID 1b81bea2 - vc1 decoder (mode C)
 GUID 49761bec - unknown
Therefore i am suspicious whether Intel UHD 620 GPU support HEVC decoding?
In addition, in the above list there are unknown decoders (i.e. not mentioned in https://gix.github.io/media-types/ ).
VARADHARAJAN
Valued Contributor II
by using uhd 630 we cant find technical specifications , sir will you tell processor model and name , its depends upon the intel processor model
SRiab
Let remind that my GPU is UHD 620. How can I depict GPU model? From device manager I only found the following info on my GPU: PCI\VEN_8086&DEV_5917&SUBSYS_07E61028&REV_07 PCI\VEN_8086&DEV_5917&SUBSYS_07E61028 PCI\VEN_8086&DEV_5917&CC_030000 PCI\VEN_8086&DEV_5917&CC_0300
David_V_Intel
Hello SRiab, Thank you for posting on the Intel ® communities. To better assist you with your request, I will need to check some information about your computer. Please follow these steps: 1. In the keyboard, press WinLogo key + R. 2. In the Run box please type dxdiag and hit Enter. 3. Click on Save All Information (save it in your desktop). 4. Attach the report to this thread. Regards, David V Intel Customer Support Technician Under Contract to Intel Corporation
SRiab
Hi David V I attach the dump of ‘dxdiag’.
SRiab
Oops, i forgot to attach the dump in the previous message.
David_V_Intel
Hello SRiab, Thank you for your response. I was reviewing the information and the specifications of your processor and in fact it should support HEVC decoding, you can check the information in the link below: https://www.intel.com/content/dam/www/public/us/en/documents/datasheets/7th-gen-core-family-mobile-u-y-processor-lines-datasheet-vol-1.pdf On page 29 you will find the hardware accelerated video decode. Now, I would like to know if you have actually had problems when trying to decode this or is it just shown in the report that lists the supported decoders you generated? Does this happen in every software that asks for a decoder or only one? If possible, please let me know the software you have used to check that. Regards, David V Intel Customer Support Technician Under Contract to Intel Corporation
David_V_Intel
Hello SRiab, I am following up with your case and see that we have not heard back from you. If you need more assistance do not hesitate to reply. Regards, David V Intel Customer Support Technician Under Contract to Intel Corporation
SRiab
Thanks David
Frankly speaking, upon restarting my laptop DirectX succeeds recognizing hevc hw:
found hw support: guid[5b11d51b-2f4c-4452-bcc3-09f2a1160cc0]
hw acceleration enabled - decoder[H265] format[NV12]
Have you a test program to decode hevc-stream?
David_V_Intel
Hello SRiab, Thank you for your response. We do not have a software like this, nevertheless, you can try looking for a third-party one and check. I am really glad to know that DirectX now recognizes the HEVC. I will proceed to close this request, if you need any more assistance let me know. Regards, David V Intel Customer Support Technician Under Contract to Intel Corporation
