23109 Discussions
Does latest driver fix igfxem ownership issue?
lczor
So for a while now i've had an issue with Steam, where i couldnt update certain games, and it's because I didnt have ownership to the files as they were taken over by a 3rd party.
I did some looking about online and found i wasnt alone and others had the same issue, and noticed that there was a thread on your forum relating to it
igfxem module denies access to my folders">
My question is, do the latest drivers such as hd530 v21.20.16.4534 have this fix incorporated into it?
I ask as i'd prefer to know before trying it out as if it isn't fixed, then i'll end up having to reformat my drive to remove the game.
Stefan3D
This driver is out-of-date.
If you use Windows 10, try
Or for older OS https://downloadcenter.intel.com/download/26836/Graphics-Intel-Graphics-Driver-for-Windows-15-45-?product=88345 Download Intel® Graphics Driver for Windows* [15.45]
Why? Just uninstall the game.
lczor
You can't uninstall it, because certain files become completely locked out. Tried to manually take ownership but nothing would work so easiest option for me was to format.
Hello cz1,
I understand you are not been able to update certain Steam games due to some files are locked.
Let me apologize for any inconvenience this issue may be causing to you.
This issue was fixed since graphics driver build 4664. Newer versions of the graphics driver should include the fix too. Were you able to install the graphics driver that was provided by Stefan3D?
In case you still need assistance just let me know.
Fred D.
lczor
Hi Fred,
I hadnt tried it yet, as it wasn't made clear that all newer version had the fix, so didn't want to try it encase it didnt work and i have to reinstall about 750 gb of games :S
Will give it a try tonight, and see how it goes.
Hello cz1,
Thanks for the update.
Please install the graphics driver as soon as you can, and let us know the results.
Fred D.
lczor
Upon installing the latest driver, i am now getting this happen every time i reopen my laptop from hibernation. Only way around it is to shut down using the power button and restart the laptop.
I ran a scan to check for viruses but none showed
Hello cz1,
I am sorry to hear you are still having issues with your computer.
In order to help you better I would like to gather more information about the configuration you have in the computer. Please attach to this thread the .txt file the Intel® System Support Utility will generate https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
To attach a file, you must click "Use Advanced Editor" on the upper right hand corner of the response box, then the "attach" option will appear on the bottom right hand corner of the response box.
Fred D.
lczor
As requested the file has been attached.
To note, i reverted back to an older graphics driver for the time being.
Hello cz1,
Thanks for the information you sent to me.
The graphics driver that is currently installed in your computer should include the fix for the issue you are having with Steam.
Please check if issue persists or not with the graphics driver that is currently installed in your computer.
Only if issue persists download the graphics driver that is on this link https://downloadmirror.intel.com/26772/eng/win64_154518.4664.zip https://downloadmirror.intel.com/26772/eng/win64_154518.4664.zip
Install the graphics driver using the steps that are on this YouTube video https://www.youtube.com/watch?v=S1KzoQDjMMY https://www.youtube.com/watch?v=S1KzoQDjMMY
Fred D.
Hello cz1,
I was wondering if you still need assistance regarding the files that are locked with certain Steam games. In case you still need assistance just let me know.
Fred D.
lczor
Hi Fred,
Everything seems to be working at the moment, it's updating fine as i expect it, am i ok to keep this post open for when the graphics driver / windows needs to update so i dont have to post it all again? As i think if it's going to fall over, it'll be then.
Cheers
Lee
Hello cz1,
I am glad to hear computer is working fine now. If issue comes back at some point just let me know through this Community thread.
Fred D.
