23259 Discussions
Does the onboard Intel HD Graphics 4600 has a serial number? If so, how do you get it?
RTan4
I have an Intel 4th generation Core I7 processor with the onboard graphics running Linux OS. I was wondering if the graphics card has a serial number? Thanks!
Stefan3D
The "graphics card" is actually a part of the SoC (system on a chip).
https://downloadcenter.intel.com/download/26735/ Download Intel® System Support Utility for the Linux* Operating System
Unfold Review/detailed view/processor
For reference: on my Windows rig it looks like that
RTan4
RTan4
I got this scan result for the Display:
# Scanned Hardware
Computer:
- Display
- "Intel Corporation 4th Gen Core Processor Integrated Graphics Controller (rev 06) (prog-if 00 [VGA controller])"
Adapter RAM:"size=256M"
Capabilities:"[90] MSI: Enable+ Count=1/1 Maskable- 64bit-"
Capabilities:"[d0] Power Management version 2"
Capabilities:"[a4] PCI Advanced Features"
Caption:"Intel Corporation 4th Gen Core Processor Integrated Graphics Controller (rev 06) (prog-if 00 [VGA controller])"
Device ID:"8086:0416"
Driver:"i915"
Driver Path:"/lib/modules/2.6.32-573.el6.x86_64/kernel/drivers/gpu/drm/i915/i915.ko"
Driver Provider:"Intel Corporation"
Driver Provider:"Tungsten Graphics, Inc."
Driver Version:""
Flags:"bus master, fast devsel, latency 0, IRQ 34"
I/O Ports:"I/O ports at f000 [size=64]"
Manufacturer:"Intel Corporation [8086]"
Power Management Capabilities:"Power Management version 2"
Refresh Rate - Current:" 1280x1024_60.60.0"
Resolution:" 1280x1024_60.00"
What does the "Adapter RAM" mean? It has 256M as the size?
Thanks!
Ryan
RTan4
Another question, when the Serial Number is "To be filled up by O.E.M," where is it being read by the System Support Utility? Is it a firmware, BIOS, or flat file?
I know the serial number that I would like to fill it up.
Thanks!
Ryan
RTan4
Found the folder where the ssu.sh is reading from. I could not update the file(s), board_serial or product_serial. Can they be manually updated if I changed the permission?
Thanks!
Ryan
RyanTan@DRS: In order to try to get the information you are looking for, please visit the Linux forums, in there you will received peer to peer assistance on this subject:
http://www.linuxforums.org/forum/ http://www.linuxforums.org/forum/
Or you can also visit our communities as well for peer to peer assistance:
https://01.org/community https://01.org/community
Alberto R
