23633 토론
Doom 2016 Freezes Before Menu With HD Graphics 4600
RRafa
초급자
20,641 조회수
The game stop responding without a crash log.
The game loads 99% after the intro and then stops responding, at what i think is the menu sometimes(i can only read "Campaign" written as it freezes so i'm not really sure).
The screen becomes useless and I'm not even able to close the game, forcing me to restart after trying.
Although the graphics don't work, i can still hear audio output from the Menu screen track. Which means it's clearly a GPU problem.
I'm currently running the game on a Windows 10 with the latest Beta Driver v4474.
Attached my intel information dump from graphics properties.
Also, i'll be more than glad to provide you with any other information you need. Even test options if need be. I just need a definitive answer that it'll work in the next 12 days, because if my graphics card isn't supported i can still refund.
0 포인트
1 솔루션
AZaba
초보자
17,392 조회수
I have to confirm that the game loads the menu screen with this driver version: 20.19.15.4501
This driver was installed by the Windows Update service on my Windows 10 64 bits (v 1607 - C 14393.321)
원본 게시물의 솔루션 보기
0 포인트
26 응답
RRafa
초급자
13,561 조회수
SSU Output also attached
0 포인트
직원
13,561 조회수
Hi D-martins,
According to the release notes of the Beta driver and latest official driver 4463 the crash/hang in Doom (2016) was fixed.
Please let me know if you have the same issue with the latest official driver 4463.
https://downloadcenter.intel.com/download/26079/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen-?product=81496 https://downloadcenter.intel.com/download/26079/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen-?product=81496
Fill the sticky note out available in the link below. You already sent me the SSU results.
/thread/77761 https://communities.intel.com/thread/77761
Mike C
0 포인트
RRafa
초급자
13,558 조회수
It doen't seem to be fixed in the HD 4600.
I installed v4463 even before the latest beta and it crashes with 0xC0000005 (Access Violation) error.
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
Driver v4463 Crashes in a black screen as soon as you open it and crash log reports 0xC0000005 error - http://pastebin.com/UJ1TfNA3 Callstack Function(desc) Line Bytes File Process - Pastebin.com) ;
v4474 instead is able to start the game intro videos but crashes right after loading screens.
I can hear the soundtrack with the loading 99% frozen image, and sometimes with the word "Campaign" in a black background) but i can't close the application whatsoever.
I'm forced to restart the PC or put it to sleep to the close the application through task manager once it boots up.
Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")<p>
Always (100%): X
Often (51-99%):
Sporadic (20-50%):
Very Sporadic (<20%):
Hardware (HW)
Brand and Model of the system.
MB: Gigabyte H81M-DS2V BIOS: F6(Latest); Ram: Vengeance 2x4Gb; SSD: SanDisk 128Gb; HDDs: WD Blue 750Gb, Seagate Barracuda 2Tb.
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
Hybrid, only Intel HD Graphics.
<span style="font-weight: inherit; font-style: inherit; ...
0 포인트
RRafa
초급자
13,558 조회수
0 포인트
직원
13,559 조회수
Hi D-martins,
I have requested the game to my upper manager in order to replicate the issue with HD graphics 4600. The last official document says that the issue was resolved. Please bring me 2 or 3 business days.
Thank you for your patience in advance.
Mike C
0 포인트
직원
13,559 조회수
Hi D-martins,
Thank you for your patience. We have tested the game in our lab and these are our findings.
It was not possible to start the game at full screen using the latest driver 4474.
We were able to run the game with this workaround:
It is necessary to get the latest update of the game then start the game in windowed mode, lower down settings around 60% and finally change mode to full screen.
Please take into consideration that this is a very high end game, which requires plenty of "juice" which forces the CPU.
We use the hardware below:
-OS: Windows 10* Home 64-bit Version 1607 (Build 14393.51)
-CPU: Intel® Core™ i7-4702HQ Processor
-iGPU: Intel® HD Graphics 4600
-iGPU graphics driver: 10.18.15.4271
-dGPU: NVIDIA GeForce GT 750M (disabled for the tests)
-Motherboard Model: Dell XPS 15 9530
-BIOS Version: A04
-RAM: 16GB
Mike C
0 포인트
직원
13,560 조회수
Hi D-martins,
Verify if you already have installed the latest version of the game in your pc before playing.
Mike C
0 포인트
RRafa
초급자
13,561 조회수
Thanks but, I checked already and i'm running the latest version of the game.
This workaround i can't figure it out though.
How can i start it in windowed mode and lower settings if i can't get to the settings menu?
Also, you tested on a completely different setup, how can i know this is anything like my problem?
EDIT: I was able to do everything you said to get the workaround running without going through the menu and game still isn't able to open menu.
The question now is will intel fix it?
0 포인트
RRafa
초급자
13,561 조회수
Really, it's a legit question. Release notes says it's fixed, and you saw for yourself it isn't.
Any ETAs?
0 포인트
직원
13,561 조회수
Hi D-martins,
We have confirmed the issue you are experiencing is related to the amount of RAM in your system.
Doom requires at least 8GB of RAM to work, plus additional memory for video, however, the integrated graphics are taking (shares) memory from the RAM so the game is no capable to run in your system.
It is necessary to add more RAM in your computer. I suggest you 16GB or at least 12GB.
DOOM 2016 system requirements
http://gamesystemrequirements.com/game/doom-2016
Mike C
0 포인트
AZaba
초보자
13,561 조회수
Hi:
I have the same problem and I have 16 GB or RAM.
The game loads 99% after the intro and then stops responding and I can still hear audio output from the Menu screen track.
The screen becomes useless and I have to kill the process to quit the game.
Sometime ago I tried the alpha version of the game and I played it with older drivers.
I do not understand why with the lastest official intel drivers the problems persists.
0 포인트
RRafa
초급자
13,561 조회수
Yes, that's because they really don't want it to be their fault.
I solved the problem. I wasn't going to post in here just because how angry i was about them always trying to make you spend more money just to fix a simple software issue.
But since you're having the problem as well.
First off, update your intel drivers to v4501.
Then disable shared RAM with your video card in BIOS..
It should be working.
0 포인트
AZaba
초보자
13,561 조회수
I am afraid that Intel drivers v4501 (20.19.15.4591) stucks at 99% and I still hearing the audio output in Windows 10.
I have tried Windows 7 but the lastest drivers are version 15.36 and the game doesn't start.
0 포인트
RRafa
초급자
13,561 조회수
Make sure you also have the latest version of the game.
And by the way, can you link me to the version you downloaded?
0 포인트
AZaba
초보자
17,393 조회수
0 포인트
직원
13,561 조회수
Can this issue be closed?
I see that you guys are reporting that the game menu does not freeze after loading driver version 4501.
Thank you all for your feedback.
Allan.
0 포인트
AZaba
초보자
13,561 조회수
Yes, this issue can be closed.
Thanks xD
0 포인트
직원
13,561 조회수
Great, thank you.
Allan.
0 포인트
DDona5
초급자
12,525 조회수
I have the same problem "Doom freezes before menu with HD graphics 4600" . I've tried all you wrote in here and nothing changes.
For your information i have the latest version of Doom
I've loaded and installed the driver version: 20.19.15.4501 ( And also the latest version available too)
Nothing works!!! I can't manage to play the game and the upcoming games either....
Is there any fixes to this or do I have to change my graphic card?
System information:
Windows 10
Processor: Intel Core i7-4790K CPU 4.00GHz
Memory RAM: 16,0 Go
Thank for for any answer that can help me...
Cheers,
D
/message/413751# 413751
0 포인트
응답
