23259 Discussions
Driver crashing after some time when playing Arma 3
A22
Hi. I have a problem the game, ArmA3. After a good 10 to 60 minutes (and if i'm lucky, up to 120 minutes) of playing the game, the game freezes and these error messages are displayed:
"Display Driver Stopped Responding and has recovered"
"DX11 error : buffer Map failed : DXGI_ERROR_DEVICE_REMOVED"
And once these both happen, the game will then crash. These errors have been happening since I first got the game. The game also has a minimal requirements to run the game, which my computer meets them all.
I use: Intel(R) HD Graphics 4000
I attached the DxDiag.txt at the bottom. My graphics driver should be up to date.
Jose_H_Intel1
Please try the suggestions given here: http://www.intel.com/support/graphics/sb/cs-009483.htm Graphics Drivers — Errors Reported By Microsoft*
A22
Thank you for replying Joe, but from looking at the website you sent, I looked at all the information that was provided in it and done anything I tried to from it, but with still having the problem. I looked up more information on this topic and found out that a lot of people are having the same issue and getting the same errors as I.
ROBERT_U_Intel
Hi Alex
Would it be possible for you to install the latest Intel HD Graphics driver an test this issue?
The 15.33.32.4061 has been posted to Intel Download Center at the following direct links to the drivers:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=24593 64 bit version
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=24592 32 bit version
Robert
A22
Thank you for also replying, Robert, I have downloaded the 64 bit version of the newest version for the driver, and with no such luck. I did find out from searching online about this problem, their is a certain driver version that does not have this problem? I'm not sure which version nor if this is a true fact, but I will continue my hunt for a solution online.
