23581 Discussions
Driver problem
Enoksy
Hi, i have an update to do of graphic driver but it tells me when i do it: "the driver is already installed" and that cancels it.
If someone knows the solution. Thanks.
(Sorry for my english, i'm french)
AlHill
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
Enoksy
this is the document.
Enoksy
it had finally work. Thanks for the help!
Victor_G_Intel
Hello Enoksy,
We appreciate the report, please let us know if you are still having this issue since based on your last message we would assume it has been fixed; however, please confirm this so we can either proceed with the support or proceed to close the thread.
I look forward to hearing from you.
Victor G.
Intel Technical Support Technician
Victor_G_Intel
Hello Enoksy,
Please let me know if you need further assistance.
Victor G.
Victor_G_Intel
Hello Enoksy,
We have not heard back from you.
If you need any additional information, please submit a new question as this thread will no longer be monitored
Victor G.
