23789 Discussions
Drivers not installing on Windows 1
EBeru
Im trying to install the latest drivers for windows 10 (15.40.4.64.4256) Every time i try to install it, it gives me an error, Manually and Automatically,
Any way i can fix this?
IStef1
This driver is not compatible with your system . maybe with windows version or generation on your cpu. Just try you to find compatible driver
Marvin_L_Intel
Hello ZekeB,
According to the screenshot "Error 2.png" it seems that the controller you have is the Intel® G45/G43 Express Chipset. I regret to inform you that the graphics controller that you have is not compatible with the operating system that you are running. You can confirm that on the link below:
http://www.intel.com/support/graphics/sb/CS-034343.htm Graphics Drivers — Supported Operating Systems
As an alternative solution you may consider downgrading to an older operating system or getting a graphics card that can be supported by your computer and the operating system you have.
If you have more questions please let me know.
marving_intel
