23539 Discussions
Drivers refuse to install.
miyagi90
Hey there,
i know this issues is known, and for some people it seems to be solved but i can´t for the love of all thats holy install a new driver in a normal way.
Why?
Because the the Online tool fails and if i manually download the drivers, the moment the extraction is done the "installing drivers" window just closes without any message.
I tried everything except completely whiping my ssd and installing a fresh windows (did the ddu install tried alle methods to install it just wont work).
Until now i didn´t realy have a problem with that but since the last ddu deinstall my arc control center is gone WHICH I CAN`T INSTALL WITH THE DEVICE MANAGER!!!!
Seriously...
Intel Come on please effing fix this.
Im willing to do everything besides whiping my drive and do a fresh OS install.
Edit:
I was able to install the Arc Control Center by extracting the folder and opening the installer in the folder.
By the way Starting the Arc Center did change my brightness settings so im pretty sure i kinda found the problem which resets brightness values after Booting : Arc A770 High Brightness After Start and DP Monitor Not posting - Intel Community
ACarmona_Intel
Hello Miyagi90,
We are checking in with you to know if you have already performed the OS clean installation, and may we know the result?
By the way, if you have any additional queries, Please know that we would be happy to assist you if you have any.
Thank you, and have a great day!
Carmona A.
ACarmona_Intel
Hello Miyagi90,
Thank you so much for the response, and we hope that after a clean installation of OS, the issue will be resolved.
And by the way, your patience and understanding while we investigate the issue are truly appreciated.
We will close this enquiry now. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Thank you, and have a great day ahead!
Carmona A.
THETECHGUY712
just faced the same problem but i just changed these two in bios
1). enable intel (R) SGX. in security
2). Graphics device [Switchable Graphics]
save and exit
and intel driver & support assistant picked up the automatically and its installed now working properly no issues
am offline installer should also work for you
